Tip & How-To about Nokia E71 Smartphone
Nokia Symbians Secret Codes
Nokia Code function
*3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
*#4720# With this Nokia code you can deactivate the Half Rate Codec
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
*#9999# Phones software version if *#0000# does not work
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
#pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
*#147# This lets you know who called you last (Only vodofone)
*#1471# Last call (Only vodofone)
*#21# This phone code allows you to check the number that "All Calls" are diverted to
*#2640# Displays phone security code in use
*#30# Lets you see the private number
*#43# Allows you to check the "Call Waiting" status of your cell phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
*#67# Allows you to check the number that "On Busy Calls" are diverted to
*#67705646# Phone code that removes operator logo on 3310 & 3330
*#73# Reset phone timers and game scores
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
*#7760# Manufactures code
*#7780# Restore factory settings
*#8110# Software version for the nokia 8110
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
*#94870345123456789# Deactivate the PWM-Mem
**21*number# Turn on "All Calls" diverting to the phone number entered
**61*number# Turn on "No Reply" diverting to the phone number entered
**67*number# Turn on "On Busy" diverting to the phone number entered
12345 This is the default security code
press and hold # Lets you switch between lines
Symb OS v6.1
    Nokia 7650
    Nokia 3650
    Nokia 3660
    Nokia N-Gage
    Nokia N-Gage QD
    Siemens SX-1
    Sendo X
Symb OS v7.0
    Nokia 3230
    Nokia 6600
    Nokia 6620
    Nokia 6260
    Nokia 6670
    Nokia 7610
    Panasonic X700
    Panasonic X800
Symb OS v8.0
    Nokia 6630
    Nokia 6680
    Nokia 6681
Symb OS v8.1
    Nokia N70
    Nokia N90
Symb OS v9.1
    Nokia N91
    Nokia 3250
    Nokia E60
    Nokia E61
    Nokia E70
    Nokia N71
    Nokia N80
    Nokia N92
Nokia phones service codes
*#0000# - SW version
*#06# - IMEI
*#war0anty# - SIMLOCK info
*3370# - Enhanced Full Rate ON
#3370# - OFF
*4720# - alternative sound quality codec ON
#4720# - OFF
*#7780# - default factory settings
*#7760# - production serial no.
*#2820# - Bluetooth info.
*#73# - reset phone timers and game scores.
*#7370925538# - delete all the content of the wallet and the wallet code.
*#7370# - soft format — erases all telephone memory.
[Green]*3 - hard format — if only the telephone memory is formatted, puts back the attitudes and reboots
*#delset# - MMS/GPRS settings removal
NOTE: code depends on phone model
Nokia E71 Smartphone Logo
i want all secret cod of nokia n72 and all software code plzzzzzz thank you
*#06#
To check the IMEI.
*#0000#
To check the firmware version and date
*#92702689# *#war0anty#
To check the IMEI. The date when it was purchased
and the date when it was repaired.
*4720# (*hra0#)
To activates the Half Rate.
#4720# (#hra0#)
To deactivates Half Rate.
*#3370# (*efr0#)
To activates Enhanced Full Rate.
*#746085685# (*#sim0clock#)
To check the SIM clock status.
*#7220# (*#pca0#)
To activate the GPRS and Packet Common Control
Channel(PCCCH) supports.
*#7230# (*#pcd0#)
To deactivate the GPRS and Packet common control
channel (PCCCH)supports.
*#7760# (*#ssn0#)
To check the manufacturing serial number.
*#2820# (*#bta0#)
To check the Bluetooth MAC address
(Phone must have a built in bluetooth adapter).
*#7370925538# (*#res0wallet#)
Reset the mobile wallet.
NOKIA PHONE CODES :
Nokia Codes : *3370#
Nokia Codes : #3370#
Nokia Codes : *#4720#
Nokia Codes : *#0000#
Nokia Codes : *#9999#
Nokia Codes : *#06#
For
Nokia Codes : #pw+1234567890+1#
Nokia Codes : #pw+1234567890+2#
IDRISH 911
Nov 11, 2010 | Nokia N72 Cellular Phone
Code to increase my ringtone volume on Nokia 3110c without going to edit my profile cos i have some sticky keys (Down Key)
*3370# / #3370# Activate / Deactivate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
*#4720# / *#4720# Activate / Deactivate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
Aug 29, 2009 | Nokia 3110 Cellular Phone
11,140 people viewed this tip
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
