Tip & How-To about Fargo Persona C16 Thermal Printer
USB to serial Cable Problem
Windows will recognize the printer but fails to print. I have installed the driver but nothing. It will print fine using the regular serial cable.
Fargo Persona C16 Thermal Printer Logo
installing hp 1510e, plugged cable, wiil not recognize
then try to install manually, under Windows click add new printer,...
then find your printer on list and choose it.... and install it....
use drivers either to load by Windows automatically, or use path to your CD with software and drivers
Jan 13, 2014 | HP Deskjet 1510E Inkjet Multifunction...
zebra 105sl can't connect to new windows 7 pc
What motherboard is in the computer? USB to serial drivers can be chipset specific.
Apr 01, 2017 | Office Equipment & Supplies
Have hp deskjet 5550 printer. It's using a parallet to usb cable. It works fine in XP both locally and on network. Installed Windows 7 and it prints a small part of page, another part of page and so one. One page of print is printed on 10 to 20 sheets of paper. I'm using the windows 7 driver.
There could be conflict with the printer and the drivers you have installed. You have installed the pre-loaded ( In-OS ) drivers for the HP Printer
I have 2 possibly solutions for this issue
1. Right click on the printer icon and click troubleshoot
Continue with the Troubleshoot Wizard and try printing.
If this does not work
2. Click on start button
Right click on Computer
Left Click on Manage
From the window Click on Device Manager from left panel
Under device manager You will find Imaging device and below you will find Universal Serial bus controller
Click + sign on Universal Serial Bus control and locate the USB port assigned for HP Printer
Right click on the Printer name assigned on port and Click Uninstall Drivers
The drivers will be uninstalled
To install the drivers back, Disconnect the USB Cable from PC or Printer and plug back. It will start installing the drivers
This should be helpful to you.
Oct 21, 2010 | HP DeskJet 5550 InkJet Printer
can't print using USB connection
Unplug printer and un install software. Delete printer in printers folder. Restart pc. Install software first and then connect printer. Also make sure your usb drivers is correct.
Sep 29, 2007 | Samsung ML 1210 Laser Printer
1,298 people viewed this tip
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
pkwc
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
