Tip & How-To about HP Officejet 6310 All-In-One InkJet Printer
Printer reset
There are 2 ways to reset the printer. soft and hard reset, but nothing important happened, just errase some personal data stored in the printer memory.
here there are.
soft reset:
press and hold # + 6
unplug the power cord
plug the power again
turn in on the printer
wait until the printer turn in off automatically
release # + 6
you will find the setup menu and must fill all your custom data again
for hard reset is the same thing than soft reset but with the keys # + 9, the difference is that you will need to fill additional custom data.
HP Officejet 6310 All-In-One InkJet Printer Logo
how do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Apr 15, 2015 | Coby kyros Tablets & eReaders
nokia e7 caller display not working
is the caller number display or nothing at all?
if the caller number is displayed,check you contact,might have enter same caller number even if different names.
if not,try to reset your phone,go to settings and restore factory default or just type *#7780# for soft reset (nothing will be erase and back to default) or *#7370# for fukk format or hard reset (this will erase all of your data stored,be sure to back up important data defore proceeding)
Jun 08, 2011 | Nokia Cell Phones
no light on lcd
If your Nokia C3 meet a permanent problem, you should reset your phone. There are two ways to perform a reset on the device, the hard set and soft reset.
1 how to perform hard reset on Nokia C3
To perform a hard reset on the C3, press *#7370# and press Dial. The phone will request the security code that is 12345 by default. Since the hard reset will erase all date in your phone, you should backup important data before performing a hard reset.
2 how to perform a soft reset on Nokia C3
If you want to soft reset your Nokia C3, you need to press *#7780# and then Dial. The default security code is 12345. When you do this, your phone will come back to original factory status, but you will not loose personal data. It is better to make a backup before performing any kind of reset.
Hope this helps.
Let me know if you need more information
Thanks.
Apr 26, 2011 | Nokia C3 Cell Phone
I have a Dell axim x5 and it is stuck on a blue screen with the Dell logo. I have tried a maste reset like hold the power botton and the reset for 2 sec but after that i get a screen with the option clear all data in the memory or cancel this operation. I have tried both option but still nothing stock on the same blue screen. Please help thank you
Perform a Reset
Soft Reset
When you perform a soft reset, the device deletes any data that has not
been saved but saves any data that has been stored in memory. Try
performing a soft reset if the device does not respond when you tap the
display or press a button.
To perform a soft reset, use the stylus to press the reset button.
Hard Reset
NOTICE: When you perform a hard reset, you lose all the data stored on
your device.
Perform a hard reset if:
• You want to delete all the data stored on your device.
• You forget your password and need to clear it.
• Your device is experiencing severe operational problems and you have
already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you
perform a hard reset. See ActiveSync Help on your computer for more
information.
To perform a hard reset:
1 Press and hold the power button.
2 With the stylus, hold the reset button for about 2 seconds.
3 Follow the instructions on the screen.
Feb 12, 2011 | Computers & Internet
6,896 people viewed this tip
Seeker5211
Seeker5211
