Tip & How-To about Brinkmann 815-3786-0 Turkey Fryer
Bypass Brinkmann Turkey Fryer Thermocouple
I bought my fryer in November 2010 and it worked good for that Thanksgiving. Went to use it this year and thermocuople kept shutting off. So I used a brick to kep red button pressed in. What a pain.
After turkey day I removed my thermocouple and installed a direct conection.
I'm not sure about the exact thread size the Brinkman hose end and brass fitting on burner uses. I tried using a 1/16" NPT fitting but it is incorrect. However, I found 8mm threads to be the closet. Use thread sealant and it works great!
I bought a McMaster-Carr p/n 93590A220; Metric 18-8 Stainless Steel Coupling Nut M8 Screw Sz, 1.25mm Pitch, 38mm Length, 16mm Width, $7.95. and used it to connect the hose end to brass fitting on burner.
Yes this is considered a safety risk so modify at your own risk. No one I know of ever walks away druing use.
hth
Kenneth
Brinkmann 815-3786-0 Turkey Fryer Logo
In what month and year is Mad Men set?
Season 1 opens in March 1960 and finishes Thanksgiving Day, 24th November 1960. Season 2 picks up on Valentine's Day, 14th February 1962 and ends in October 1962 with the peaceful resolution of the Cuban missile crisis. Season 3 starts somewhere during Spring 1963 with Betty Draper (January Jones) being approximately six months pregnant and ends on the evening of 16th December 1963. Season 4 begins around Thanksgiving in November 1964 and ends in October 1965. Season 5 begins on Memorial Day weekend in May 1966 and ends in March 1967. Season 6 begins at Christmastime in December 1967 and ends on Thanksgiving Day, 28th November 1968. Season 7 begins in January 1969, around the inauguration of President Richard Nixon and ends mid-season on the morning of 22nd July 1969, two days after the successful moon landing of Apollo 11.
Sep 04, 2016 | Mad Men (2007)
cannot get burner to stay lit-gas going thru it but when red button released it goes out
I bought my fryer in November 2010 worked good for that Thanksgiving. Went to use it this year and thermocuople kept shutting off I used a brick to kep red button pressed in.
After turkey day I removed my thermocouple and installed a direct conection. I used a McMaster-Carr p/n 93590A220; Metric 18-8 Stainless Steel Coupling Nut M8 Screw Sz, 1.25mm Pitch, 38mm Length, 16mm Width, $7.95. I'm not sure about the exact thread size the Brinkman hose end and brass fitting on burner uses. However, I found 8mm threads to be the closet. Use thread sealant and it works great!
I tried 1/16" pipe fitting bit it is not correct.12_5_2011_6_08_54_pm.jpg
Nov 25, 2010 | Brinkmann 815-3786-0 Turkey Fryer
will not update Xbox live
Mine did this same thing for the November 1, 2010 Kinect update. I hit yes, update now and it said it could not connect and brought me back to the prompting screen. I then shut off my xbox and turned it back on and the update went right through.
Nov 01, 2010 | Microsoft Xbox 360 Console
My fryer won't start. I lost the manual. Last
the mounting bracket on mine cracked, and the heating element has a little switch inside the only works when its mounted correctly. I need a new bracket myself.
Dec 24, 2009 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
2,379 people viewed this tip
Top Brinkmann Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Brinkmann Kitchen Appliances - Other Expert? Answer questions, earn points and help others
