Tip & How-To about Microsoft Video Game Consoles & Games
PS3 Recovery Options Screen
A lot of PS3 problems can be solved by accessing the PS3 Recovery Menu. You can do that by
1. Turn off PlayStation 3.
2. Hold the power button down until the system turns on and then off once again.
3. Once the System has been shutdown, re-press power until you hear 2 consecutive beeps .When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
7. Choose to 'Restore File System' and follow the process through.
If that doesn't work you can try some of the other options.
  • 1)Restart SystemThis option boots your system as normal without changing any settings or files.
  • 2)Restore Default Settings.Restores all default settings on the PS3 for networking, clock, video, etc. For a full list of the restored settings you can look under settings> system settings > restore defaults on your console. This should not eliminate your game saves or other saved content, including your user login.
  • 3)Restore File SystemThis will rewrite the files the PS3 uses to boot. This feature will help if files have become corrupted and are not allowing the console to boot as normal. This should not erase any of your saved data or settings.
  • 4
  • )Rebuild DatabaseThis can be a usefull feature if you have lost files on your system for no apparent reason. Try using this feature to see if it can restore those files. This will also rewrite corrupted files within the database, potentially eliminating future issues. This feature should not erase any of your saved data or settings.
  • 5)RESTORE PS3 SYSTEMThis will restore your system to original including, formatting and erasing all of the data on the HD and returning all system settings to default. This will not take your system back to a previous Firmware release. Use this option as a last resort, unless you have nothing on the console that you want or you want to erase everything on the console, do not use this option.
  • 6)System UpdateThis will allow the user to update their console with new firmware via a Flash drive or other portable media. This will not allow you to update via an internet connection. This can usefull if your system has become corrupted to the point you can not boot. You will need a portable media device with the correct firmware and in the correct file structure to complete the upgrade. For further information on using portable media to upgrade your system please see our section on upgrading your Firmware.
  • Posted by on
    Video Game Consoles & Games Logo
    The PS3 is a 20GB disc and the ext hard drive a WD Elements 1TB drive has been formatted FAT32. The PS3 has saved about 100GB of data but the files are not accessable via the PSA USB saved data function, it just says no saved data. I want to access the individual files when on the PS3 as I would on my PC (selecting the second disc for example)
    You can try the steps below. Its from PlayStation Forum:
    1. Turn off Playstation®3.
    2. Hold the power button down; the system will turn on and turn off once again.
    3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
    4. When you hear the 2 beeps take finger off power button.
    The current Recovery Menu supports:
    • Restart System: Restarts the PLAYSTATION®3 System.
    • Restore Default Settings: Reset all system settings back to default.
    • Restore File System: Checks for corrupt/missing system files.
    • Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
    • Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
    • System Update: Update the PLAYSTATION®3 System
    If the above steps still does not solve the problem, then I think will have to update your Ps3.
    Update your PS3 (in the settings menu the 1st option).
    Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
    well as cookies.
    You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
    But if your problem is not still solved, then maybe you should call sony for further assistance.
    I wish you good luck
    Aug 16, 2011 | Sony Playstation 3 (PS3) Console
    Updated! Convergence Problems & Solutions - With example photos
    We can move red and blue up down left right but dont know where to leave them....need help aligning them
    Aug 31, 2009 | Philips 46PP9302 46" Rear Projection...
    when i turn on my ps3 it just comes up with green light and no signal on the tv people are saying go into recovery mode and restore the ps3 wen i click on any it sais cant access hard disk and it wont let me update plz help i just got it from game in my town center yesterday and iv got 30 warrenty will they take it back
    well as cookies.
    Jun 19, 2011 | Sony Playstation 3 (PS3) Console
    2,005 people viewed this tip
    Top Microsoft Video Game Consoles & Games Experts
    Tre Elkins
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
