Tip & How-To about iPhone Apps
Save battery power by turning off your apps..
I`ve discovered that my I-Phone`s battery power kept running down really fast, the problem is that all the apps that you use thru-out the day stay open and drain power from the phone. I found out I had like 40 open at once!!
to tun them off.. get to you apps page and double click round button at bottom of phone. you will get a row of 4 apps at the bottom of the screen. hold down one of the apps, and they will start shaking. just click on the "-" minus sign and begin to close them all out. it does not delete the app, just closes it. welcome to more battery life!!!
iPhone Apps Logo
WHAT CAN I DO TO SAVE BATTERY LIFE ON MY SAMSUNG GALAXY ATTAIN SCH-R920
There are many free apps on the google play that can assist in saving battery life. Each one is slightly different and it really depends on your preference. For example, JuiceDefender can help you maintain proper profiles for your phone so it uses the least amount of power possible depending on the situation. Or ES task manager which helps your delete running processes and apps.
Other than apps the best way to save battery is really to change certain settings.
1. Do not use live wallpaper. Although they look nice they **** up a lot of battery life.
2. Turn off Wi-fi, data, gps, bluetooth when you are not using them. They also drain battery like crazy. you can get a simple widget to easily control them on your front screen.
3. Turn down the brightness of the screen and amount of time it stays on because typically the screen is one of the largest battery hogs.
4. Disable apps that automatically sync like email or certain games.
5. Limit the amount of storage space used. so uninstall things you don't need.
6. If your phone is rooted, there are even more options and apps to limit the things running on your phone to increase battery life.
Oct 26, 2012 | Samsung Galaxy Attain 4G for MetroPCS with...
Android conquerer common issues
Try getting advanced task killer its a free app n shuts down the running apps,adjust ur screen brightness,and wifi,4g,and GPS also will use alot of battery so if ur not using them turn them off also,and internet use will use alot of battery,also power ur phone off every couple days it helps clear running apps and helps the phone run faster,and another thing u can try is an app callep easy battery saver it lets u set ur phone in different modes to save battery or u can do custom settings if none of this works u may have a beat battery,hope this help
Apr 08, 2012 | Cell Phones
how ddo i delete unwanted apps from my pixel?
How to delete apps from your iPod Touch, iPhone or iPad topic_ipad.png topic_iphone.jpg topic_ipod.jpg So you've downloaded, perhaps even purchased, some of the new iPhone/iPod Touch/iPad apps from the App Store. Then you discovered you don't really want or need that app. This tutorial will guide you in deleting it from your iPhone, iPod Touch and/or iPad.
  1. On the springboard, locate the app you want to delete. For this example, I'll use
Tap and hold down the icon of the application you want to delete. After a few seconds your screen will start to "wiggle" and an X will appear next to each of the apps you've installed via the App Store.
  1. WeatherBug.
Aug 25, 2011 | Palm Pixi Cell Phone
phone is running slow and wont let me type
Your phone's RAM memory go down because some application are running in background in your phone, uninstall them your phone become fast.
Jan 20, 2010 | Lands Phones
battery low
battery can low after attending 4 to 6 calls per day after full charging
Jan 02, 2009 | Nokia 6681 Cellular Phone
663 people viewed this tip
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
