Tip & How-To about Health & Beauty
Deordor on body
Sanitizer can be use to remove ordors in arm pits. When we have the ordors, we apply sanitizer to arm pits or any place in the body that had the ordor, then wipe it away, the ordor should be remove immediate. I help when we are in hurry for the meeting and avoid to disturb others.
Health & Beauty Logo
how do i remove the uv bulb
Place your finger in the door recess on the right-hand side of the sanitizer and pull open the door.
Remove the drip tray.
Remove the protective screen by gently lifting it up and pulling it forward.
To remove the UV light bulb, pull it out of the lamp holder.
Install the UV light bulb by snapping it into the lamp holder.
Align the pegs on the protective screen with the slots in the reflective surface of the sanitizer on either side of the UV light bulb.
Insert and gently push down the screen to secure it in the sanitizer.
Reattach the drip tray.
Dec 13, 2014 | Air Purifiers
The inside bottom of our CMA dishmachine is pitting and has a hole through it. It is supposed to be stainless steel. The company said it was because we had too much iron in our water? We had the water tested by 2 sources and found that not to be the case. We had it for 6 months when this started to happen. Now CMA will not replace it because they say water problems are not covered. We don't have a water problem. Has anyone else run into a problem like this?
This is usually caused by a leak in the plastic chemical line on the sanitizer. Over time and it doesn't have to be long time for it to happen, the chlorine sanitizer drips on the stainless causing it to pit. Contact your chemical supplier to check this out; The sanitizer is corrosive to stainless when not mixed with water in the machine
Oct 19, 2010 | Cma Dishmachines AFB Dishwasher
I have a three year old Hobart. I am not sure
Look on the top edge of the door to find the data plate. It sounds like an SR24, if the leds are on the left of two temp gauges. If your sanitizer pump has a tired silicone tube that is flattened from use, it will not draw chemical. if you have an air bubble in the sense board at the back, it will think you have run out. If you have changed the type of chemical or diluted it, the board will need recalibrating to suit. Put some sanitizer in a small vessel with the pickup tube and monitor the amount delivered. Usually one is looking for 50 ppm solution of bleach and rinse water.( test with litmus paper) If you have an SR24H with a booster, you don't need bleach sanitizer and holding the sanitizer button will turn the sense off.
Jun 16, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Moyer Diebel Model 201LT heating element failures
Without looking at your defective elements it sound like the chemical eat through the element and produce tiny pits tell your Eco Lab Tech to change to another type of chemical they have many kinds to suit your need. Try that . God Bless.
Feb 22, 2008 | Moyer Diebel 48 in. SW400 Dishwasher
3,404 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
