Tip & How-To about Garden
Winterizing
All you out there with lawn and garden tools that have gas motors, just wanted to remind you that they need to be winterized. In the spring we dont want to have problems with our equipment stalling, not starting, or even blowing up.When I know I wont be using my equipment for months at a time I do the following to make sure my equipment will remain in good working order for years to come without me becoming frustrated after they have been stored and then cause me time and trouble by not starting or creating other issues and wasting my time.To winterize 1st drain all the fuel from the tank and pull/crank motor till all old gas is out of line and replace fuel filter if possible.2nd drain oil if possible3rd remove oil filter if it has one4th install new oil filte5th re install oil plugBut DO NOT add oil till NEW season6th make sure gas bulbs are lubricated so they will not crackMake sure all debris is removed and all screws are secure.This is the basics for more in depth information you should always read the OWNERS manual.Next year when you are ready all you need to do is add oil, gas/gas-oil mixture and your set for the season for the most part.
Garden Logo
pony lawn mower wont start replaced spark plug and fuel filter now probably need to get to carbuerator. dont know how to disconnect ti
alot of times fuel goes stale over the winter, if this is the 1st time its been used this season you will need to drain the gas and use fresh. it will be hard to start but if that is the issue it will start.
May 26, 2011 | Garden
have murray 17.5 hp ridding lawn mower after winter got new battery and when starting it ran great but the next week it when starting it it would spit alot of gas out of exhaust, had a shock from positive term to chasy spring for second. but corrected that.
It sounds like the carburetor float might be sticking. After sitting for a winter, it could be gummed up. Shut off or stop gas flow, open the float bowl, ensure that the float has no gas in it. Next ensure that the float moves up & down smoothly. Last, hold the float up and open the gas flow to the carb, it should stop when the float is held up and start when the float is allowed to drop.
Good Luck.
Gary
May 15, 2011 | Garden
8 year old Eagle I Craftsman 6.5 starts and quits? Help!
it sounds like a gumed up carb strip the carb and clean out all the running jets with carb cleaner,,,dont go poking wire into the jets you will only distroy them,,,also check that the air cleaner is clear if its cloged up the engine cant breeth and wont rev up and it will be running very ritch as well,,,check you have good flow of fule from the fule tank,,,winter takes its toll on garden tools that are stood up most of the time
Jul 10, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
880 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
