Tip & How-To about Stainless Dishwashers
Water well cleanig
Everybody living in the country with a water well, should and can clean their well with peroxide. A safe fashion is to use sodium percarbonate.Depending on the product and strenght, use apprx 4 litres of sodium percarbonate in well, run a garden hose back to well, then make water run for apprx 8 hours at 1/4 flow.Open all fawcets in the home , one at a time for a period of 5 minutes to alllow the well water contact your piping, thus cleaning these.Leave to sit overnight, with garden hoe removed.Reconnect hose in the morning, flush for an hour or so or until you run out of water. Do not let your pump run dry for any extended period of time otherwise you will burn the pump.You know the sodium percarbonate is gone when the water is free and clear of foggy looking airated water
Dishwashers Logo
What affect does taking 35% food based hydrogen peroxide has ?
Don\'t drink it.
Small amounts used for mouth wash occasionally are okay when spit out.
Cleaning water heater with hydrogen peroxide is fine... because H2O2 is not poison outright.
Gene
Nov 01, 2014 | Water Heaters
whirlpool dishwasher manuals
I would run a couple (or more) cycles using TSP (tri-sodium phosphate), it's safe to use with dishes. That should cut the grease and make glasses sparkle.
Aug 27, 2014 | Whirlpool Dishwashers
Should I add hydrogen peroxide to my aquarium water?
In order to ensure that the water in your aquarium will be clean and to minimize their contaminants, Hydrogen Peroxide should be added to the water.
Sep 05, 2012 | 1topstore Fish
MY ARMSTRONG AIR CONDITIONER LEAKS WATER IN BASE OF UNIT
Your drain line is clogged with algae. unclogged it using solution with sodium hypochlorite or hydrogen peroxide.
Jul 27, 2012 | Armstrong Air Conditioner Conditioning...
630 people viewed this tip
Top Stainless Dishwashers Experts
richie46
Jack Frost
Tom Chichester
Are you a Stainless Dishwasher Expert? Answer questions, earn points and help others
