Tip & How-To about Zanussi TC7114W Electric Dryer
OK I have now fixed my own problem with EDC 47130w dryer water tank problem.
The problem was the light to tell you to empty the tank keept comming on and the dryer would stop every 5- 10 mins and the tank always empty.It turned out to be lint blocking the tank fill area.
also some other problems with the tank and O"ring seals comming off.
I have made a video of my fix to share, here click the link to play the video.
I hope this may help. Please note this model looks the same as others so might be the same but different brand?.
Zanussi TC7114W Electric Dryer Logo
My new tumble dyers stops after 10 minutes telling me the water tank is full, when its empty
Since it is new, I would call the mfr and have them look at it. It is under warranty isn't it?
Jan 11, 2015 | Zanussi Dryers
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
hey, i have a zanussi model zdc46130w. it stops drying after a few mins,and the "empty water tank" light flashes,even though the tank is empty?
the float down by the pump might be stuck......or the pump could be knackerd,................cheers
Jan 17, 2014 | Dryers
1,531 people viewed this tip
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
