Tip & How-To about Hotpoint Dryers
Keep your dryer running how it should and save money
Service your dryer every 3 months if you use it 3/4 times a week 2 times a week every 6 months it is important easy to do yourself but make sure you turn the power off 1st depending on the make or model you need to get into the inside of your dryer and vac all the lint and dust out all around it builds up on the motor and heater fan if the motor fan gets blocked it will cause the dryer to stop and you will have to wait till it cools down for it will start again not good as the motor will burn out or could catch fire if you follow my advice your machine will last longer and work better
Dryers Logo
year lo 1 time month lo 2 times weekly 4 times rojulo 6 times vachedi enti ?
year lo 1 time(12 months: 1+2=3 odd)
month lo 2 times(1 week and 3 week these are odd numbers)
week lo 4 times(1 Sunday, 3 Tuesday, 5 Thursday, 7 sat day)
day lo 6 times( 1o clock, 3,5,7,9,11)
Jun 07, 2010 | Nokia Lands Phones
Whirlpool dryer wed5200tq0: I have to run cycle
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
****(((Please disregard step three if this is a GAS dryer)))
Aug 21, 2009 | Whirlpool Dryers
Whirlpool Cabrio Dryer
This problem could be that the shipping parts/bolts were not removed or may not have had all of them removed.
Also it is very important to balance the machine by using a level on the sides and or top of the machine and adjust the legs.
Feb 05, 2008 | Dryers
Kenmore Stackable Washer/Dryer
THIS COULD BE THE MOTOR IF IT IS UNDER WARRANTY LET THEM PAY FOR THE REPAIRS
Dec 27, 2007 | Kenmore 98702 Stacked Washer/Dryer
1,241 people viewed this tip
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
