Tip & How-To about Technics SA-DA8 Receiver
Keeping your SA-DA8 cool
When I first bought this I noticed that it runs very hot even on low volume levels. I took it in for repair and told the tech that the fan didn't come on even when hot. He said "works as designed - the fan is output-power-driven, not temperature driven."
Wishing to prolong the life of ma SA-DA8, I used an old computer power supply and muffin fan. Plugged the PS into the controlled AC output of the amp, and the fan into the PS. Jumpered the "power-on" pins of the PS. Laid the fan on top of the amp, padded with some foam tape, and it now stays a lot cooler (and the fan is very quiet, though not silent.)
Technics SA-DA8 Receiver Logo
Cooling fan/ Radiator indicator
I would recommend first to check the coolant level. If the coolant level is too low it can cause the fan to run if it detects too low of a coolant level. Also, the low warning can be a result of a low level. Make sure to check the level with the engine cold, and not running.
Sep 12, 2017 | 2006 BMW 325i Ci
my van is running hot, what could this mean
first i would make sure the fan is coming on most turn on around 220 the fan should also turn on with the a/c on if the fan works check for leaks low coolant level will make it run hot even more when the coolant is to low to reach the temp sensor delaying fan operation
Aug 08, 2012 | 2004 Dodge Caravan
my 93 lexus ls400 keep turning off ever since i had a tuneup done. I notice that the ac condenser fan is not working but i dont run the ac.It doesn't read that it gets hot But it seem if the car g
Be sure you check engine oil level often. The low oil sensor will disable the ignition. If you turn A/C on the cooling fan should run continuous, Check the fan relays. Make sure coolant level is correct at recovery bottle, never open radiator cap. A scald hazard exist, be careful. This car is old and complicated, and is beyond your skill level to repair. Try to inquire here for advice, whenever possible. Don't throw good money at bad money
May 27, 2017 | 1991 Lexus LS 400
Chrysler LHS: Fans and AC donĀ“t work
Start by replacing the coolant cap and thermostat, then replace the hi and low radiator fan relays,
Sep 27, 2008 | 1994 Chrysler LHS
1,935 people viewed this tip
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
