Tip & How-To about Polaroid FLM-3232 Television
How to restore sound on your Poaroid flm3232 LCD TV
With perfect video but no audio, I first tried Restoring Global unlock but it did not work. Then I plugged in headphones to side of Polaroid flm3232 and got sound! Then I took my 2 stereo external speakers from my computer and plugged them into the side of the tv and got perfect sound..better than from the original internal speakers of the Polaroid....Easy instant fix AND didn't have to spend a lot of money by taking it to a repair shop. Good luck anyone who has the same probllem.
Polaroid FLM-3232 Television Logo
I have a Polaroid 10 inch tablet and when I plug headphones in I only get sound from one side of the headphones, I have tried multiple pairs, what do I do
You can try spraying a very small amount of electronic contact cleaner in the port and work the connector a few times in and out, if this doesn't work you have a bad connection with in the phone.....
Feb 21, 2015 | Polaroid Tablets & eReaders
I cannot hear any sound out of my Polaroid TDX-01930B television.
Hello
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
May 06, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
Polaroid FLM 3232 no sound
try reset config. to defaults.
on setup, defaults
Feb 20, 2010 | Polaroid FLM-3232 Television
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
Mar 15, 2008 | Polaroid FLM-2632 Television
Polaroid FLM-323B LCD TV with no sound
Same issue....went to bed last night Polaroid tv worked fine....woke up NO VOLUME>>>
Jan 13, 2008 | Polaroid FLM-3232 Television
2,485 people viewed this tip
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
