Tip & How-To about Health & Beauty
How to Shower When You Have Mobilty Problems
If you have mobility problems as a result of age or an injury it can be hard to take a shower in a conventional bathroom. One option is to convert the bathroom to be disabled accessible. This can be very costly.
A shower chair can help by allowing you to remain stable when you shower. Some models enable the user to transfer over a shower stall lip or even into a shower over bath. (Such as the Showerbuddy range)
Health & Beauty Logo
need to remove silicone from 4 part shower stall to repair & reinstall
I think you should contact to a professional who can remove this shower stall very easily without any risk. You can also have a look at shower enclosures for having such bathroom stuffs in affordable price.
Jul 14, 2012 | Home
Yellow Spots on Bathroom ceiling/walls after showers
You will have to paint over your new paint with a primer called BIN which will dry in about an hour. Then you can put your color coat on that. Problem solved.
Dec 04, 2009 | Home
How to Install Shower Curtain
If you are going to use both a shower curtain and a shower liner, you have two options for installation. You can either use one rod and one set of rings, or you can use two rods and two sets of rings. If you used one rod, line up the liner and the curtain so they are facing one another and thread one ring through each of the corresponding grommets on the both the liner and the curtain. The curtain liner will move as one unit. If you use two rods, you need one set of rings for each, and the liner and the curtain will move independently.
Aug 27, 2008 | Moen Sienna Towel Bars Black Bathroom...
1,901 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
