Tip & How-To about Maytag Ovens
Maytag Gemini MGR6875ADS
If your hitting buttons and te display is not responding be sure your not in sabbath mode if so, refer to your owner's manual and it will tell you how to get out of it. and be careful whern you are cleanning that display. make sure you don't use any ammonia based cleaners. the display will soak up the ammonia base and cause shorts in the circuit, causing you to have to replace the display board.
Ovens Logo
How do I turn SAb off my kenmore oven?
This is the Sabbath mode. If you can get the owners manual. this should tell you how to get this shut off. The owners manual is usually downloadable from the customer support page on the company website.
Nov 14, 2014 | Ovens
what does 5ab mean on the oven?
Some ranges with a lot of features have a Sabbath mode, hence the letters Sab in the display although it looks like 5ab. Check your owners manual and it should tell you how to turn off the Sabbath mode. If you don't have a manual Google your model number and Sabbath mode.
Aug 28, 2011 | Ovens
How to use sabbath mode on Maytag Gemini electric oven
Hello, Thank You for using FixYa. I will be helping you today.Holding the clock button puts it into sabbath mode.For all the info if you go to maytag website you can put in your model number and look at the owners manual.
Thank You and please rate my answer if it was helpful..
Jun 09, 2011 | Ovens
Oven display went blank. Has Power.
Hello, The first thing I'd look at is your owner's manual to insure the timer hasn't been set to "Sabbath" mode accidently. If that is the case you could experience a "no display" scenario. The manual will also explain how to enter/exit the "Sabbath" mode. In the event the timer itself is at fault ( i.e. the display transformer gone bad ) it will have to be replaced or (if an available option exist's for your timer) have your timer rebuilt. Hope that help's and please take a second and rate the info provided by me here at fixya. Thank you and good luck. macmarkus :)
Dec 07, 2009 | Whirlpool Ovens
Maytag single electric built in with a display saying sab bath
It is in Sabbath mode, used for Jewish holidays. Anyway, hold the cancel button for 3-5 seconds and it should revert back to normal operating mode. It will still bake in Sabbath mode but will not display anything due to the laws regarding observation of the Sabbath
Jun 16, 2009 | Maytag MEW6527DDS Electric Single Oven
1,459 people viewed this tip
Top Maytag Ovens Experts
Oloyede Monsuru
Mack Baxter
Craig Butler
Craig Butler
Are you a Maytag Oven Expert? Answer questions, earn points and help others
