Tip & How-To about Health & Beauty
Prevent and treat bug bites
There's a reason that insects are called pests.But despite the itchy ,red bumps they leave behind,insects bites are usually mild and the itching goes away in a day or so,specially the bug bites come from mosquitoes or biting flies.On the other hand(legs,arm or toe.....),bees,wasps and fire ants tend to cause more irritation and can some time lead to bigger problems.
Bug bites can be avoided,or at least minimized,by following a few precautions for common out door pests.The first line to defense against to plan ahead-always evaluate your surroundings and prepare accordingly if you anticipate large numbers of insects.Its always a good idea to apply insect repellent with DEET or PICARIDIN.If you r concern about using chemicals, particularly around children,you might want to try lemon eucalyptus and citronella oils, which also work.
Health & Beauty Logo
what helps bed bug bites
Hello sir/madam
Wash the bites with soap and water. This will help prevent a skin infection and help reduce itchiness.
If the bites itch, apply a corticosteroid cream to the bites. You can get a weak form of this medicine without a prescription at your local drugstore.
Or if you can't get access to a local pharmacy at the moment just apply lotion and try not to itch the bites just leave them alone
Hope it helps
Oct 31, 2016 | Cars & Trucks
what bite results in a red welt with a pin hole in the exact center?
common to many many bugs. Call your local agra office.
Sep 15, 2014 | Home
Hi, I have a red extremely itchy bumps in various sizes all over my legs and stomach. They are so itchy that I scratch until they bleed. I have had this problem for over 2 years. I have seen a number
I am not a doctor but this may be a violent allergic reaction to something in your food or environment (Wool , Pesticide, Air freshener , Deodorant, Cleaning chemical )
I think you should go down a direction of getting allergy tested to see if you have an allergic reaction .to something
http://www.labtestsonline.org.au/learning/index-of-conditions/allergies/tests?gclid=Cj0KEQiAuonGBRCaotXoycysvIMBEiQAcxV0nJRaOtlFQyhmJn62_erTUdasxpd8Ul93WYxZNXdOnvoaAvA_8P8HAQ
I have done the VEGA testing and it does highlight allergies and mineral and vitamin deficiencies usually a natropath does the vega testing just internet search vega test
Mar 10, 2017 | Health & Beauty
701 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
