Tip & How-To about Twitter Tweets
Twitter How to Create Custom Groups
Copy the RSS link at the bottom of your Twitter page.
Go to Yahoo Pipes.
Create a new pipe.
Set the URL of the RSS as the "Fetch Pipe".
Add a filter.
In the title put the real names of people you wish to follow, in case you don’t know there names, but know there Twitter nicknames use these in the "Guid field".
Connect all the pipes.
Publish it, Visit public URL of the pipe output, here's your Twitter custom group.
Found this great tip at - http://www.christopherspenn.com/2007/03/05/how-to-make-custom-twitter-groups/
Enjoy
Twitter Tweets Logo
why is the sand going back into the water Intex Sf15110
Your sand filter has developed a fault.
Normally water is filtered from the top of the sand filter through the sand to the bottom of the sand filter into the spoke pipes. The filtered water is collected by a pattern of spoke pipes that is connected to the collection box. These pipes only allow water to pass through to the return riser pipe to return the water to the pool via the selector valve.
This problem happened to me too, the fault was at the bottom of the sand filter, at the connection box, it had collapsed/cracked and allowed the sand entered the riser pipe to the selector valve that controls the backwashing, rinse, and filtering etc. and the sand and water is returned to the pool via this valve.
The can be repaired, it requires removing the control valve, removing the sand to get access to the riser pipe, and the collection box and spoke pipes. the the damaged collection box can be repaired.
Put back together in reverse order.
May 26, 2012 | Computers & Internet
Backfire
is it a straight thru exhaust, or is it just a head pipe with nothing attached? If it's just a head pipe, you need to get some sort of muffler on it or you'll burn your valves out from a lean condition. The backfire is due to the vaccum fed carbs that yamaha runs. They work wonderfully, but under heavy deceleration, the vaccum still feeds the bowl, and it builds up excess fuel, which eventually burns off as a backfire. If it were fuel injected, you could have the fuel map adjusted to lean it out under deceleration.
Jun 22, 2010 | 2001 Yamaha V Star 1100 Classic
how to replace a belt tensioner on a 2001 ford focus
Creating More Workspace:
It is necessary to remove the CAC to inlet manifold pipe (drivers side) i.e. the wide, black pipe bolted to the top of the engine, to gain access to the P.S. pump and move the Engine Coolant Resevoir to one side.
Also, to make the process easier and create additional space, it may be helpful to remove the following additional items from the car:
  • fuel filter (and plastic retaining clip).
  • oil filter (to make access easier to the nuts bolts and pipes from below the car)
  • the EGR cooler connection pipe (optional).
Essential Items:
  • 15mm Deep, Hex Socket and large 15mm Ring Spanner - tensioner mounting nuts
  • E8 Torx Spanner for removing 3 studs with T40 Torx ends (method 2 only)
  • 18mm (or 3/8W, 7/16BS) Crowfoot wrench for removing union nut on HP pipe power steering pump. (method 1 only)
  • 10mm ring or combination spanners, long and short (P.S. Pump).
  • 10mm, hex socket ( narrower 3/8" drive preferred) - power steering pump bolts (Methods 1 and 2)
  • Hose Clamp (clamping bottom hose power steering pump)
  • Teflon seal / o-ring for union on HP Line, Power Steering Pump or new union (See Notes 2 & 3)
Nov 01, 2009 | 2001 Ford Focus
RSS Feed isn't working properly in Twitter
First thing is, don't rely on many sites together. Twitterfeed works like a charm and use only that site and forget others. If you have already joined the others, remove the feed from those sites.
Just go to twitterfeed and set the options and feed and have it deliver the feeds every 30 minutes. Remember, twitterfeed will post only those new posts which you made on the blog. It doesn't tweet any older posts of yours which you had before registering with it.
Jun 11, 2009 | Twitter Tweets
454 people viewed this tip
Top Twitter Computers & Internet Experts
Lesley Cameron
Lesley Cameron
Laxman Bisht
Laxman Bisht
Sunil Pratap Singh
Sunil Pratap Singh
Are you a Twitter Computer and Internet Expert? Answer questions, earn points and help others
