Tip & How-To about Sony Ericsson T630
Change WAP button to Write New SMS (even on T-Mobile!)
I seldomly use my WAP browser than SMS service that's why I want a faster acces on SMS. So instead of WAP, the SMS service will launch in a push of the WAP button.This procedure will help you modify the WAP button such that it opens the Write New SMS, even on T-Mobile (it's possible that other carriers can bypass the step A)!
A. First, configure a dummy WAP Profile:
1. Connectivity
2. WAP Options
3. WAP Profiles
4. Add profile
5. Name: "SMS" (whatever you like)
6. OK
7. Connect using: press Edit
8. New Account
9. GSM data
10. Name: "SMS" (again, whatever you like)
11. OK
12. Phone No: "+" (hold 0)
13. OK
14. SAVE
15. IP address: 192.192.192.0 (or whatever you like)
16. Press SAVE
17. Select the profile just created (SMS)
B. Now, configure the WAP button to write a new SMS:
1. Connectivity
2. WAP Options
3. WAP Profiles
4. "SMS" should be selected. Press Edit.
5. Advanced
6. Change Homepage
7. Name: "SMS"
8. Change Homepage Address: "mailto:" (without the "")
9. OK
That’s it! Now when you hit the top-right button (WAP), it will serve as a shortcut to create a new SMS message.
Note: for whatever reason, it creates a space in the message. So, get in the habit of hitting clear once to delete the space. This will also allow you to back out of a message without it being saved in your Unsent folder.
Sony Ericsson T630 Logo
my mms messages do not send on my curve 8520, they try to send for a long time then show it failed to send, i tried sending to myself and that did not work
This could only be caused by a couple of things. The message center number in the handset may not be correct, which will cause the messages to fail. The other possibility is that the feature is not active on your account with your wireless provider. What you need to do is test a couple of things. See if you can send a text/sms message to yourself, in doing this you can verify that you can not only send, but receive text/sms messages. If you cannot send, or receive text/sms messages, then that verifies that the message/service center number is off, and will need to be corrected. If that works, and you can receive text/sms messages, then your service center number is correct, and you will move to the next troubleshooting step, which is to test your web browser. If you cannot launch the web browser on your handset, then this is an issue, because the MMS service requires that you have both SMS, and web browser service to send a MMS message. If you can access the internet and you have the ability to send/receive text/sms, then you need to call your service provider as the issue may be with their service.
Mar 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
phone is not ringing out loud, even when recieving or dialling
hello there!! Thank you for using Fixya.com;
General packet radio service (GPRS) is a packet oriented mobile data service available to users of the 2G cellular communication systems global system for mobile communications (GSM), as well as in the 3G systems. In the 2G systems, GPRS provides data rates of 56-114 kbit/s.
GPRS data transfer is typically charged per megabyte of traffic transferred, while data communication via traditional circuit switching is billed per minute of connection time, independent of whether the user actually is using the capacity or is in an idle state. GPRS is a best-effort packet switched service, as opposed to circuit switching, where a certain quality of service (QoS) is guaranteed during the connection for non-mobile users.
This GPRS can be acquired from your Service or Network Provider and there will be a minimum charge of amount on this and it depends from the Provider. You may just need to use a Mobile which supports this kind of feature.
Little more info about GPRS:
Services
GPRS upgrades GSM data services providing:
If SMS over GPRS is used, an SMS transmission speed of about 30 SMS messages per minute may be achieved. This is much faster than using the ordinary SMS over GSM, whose SMS transmission speed is about 6 to 10 SMS messages per minute.
For more information, you may contact your Network Provider.
Have a nice day!!!
Feb 15, 2009 | Sony Ericsson w580i Cellular Phone
Tips and tricks
tips & trics is inbuilt in the fon in general tab of the settings in setup wizard.....
Jul 29, 2008 | Sony Ericsson K800i Cellular Phone
using for net
you must call your operator and ask them to send you setup sms for c380!!!! Your phone have:
GSM (9,6 Kb/s),
GPRS (115 Kb/s),
WAP: 2.0
so it must work!!!
Jan 23, 2008 | Motorola Mobility C380 Cellular Phone
2,611 people viewed this tip
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
