Tip & How-To about Frigidaire Refrigerators
How To Properly Store Vegetables and Food
The first step in proper storage is making sure your refrigerator is at the proper temperature. You will want to make sure your fridge is somewhere between 34 degrees and 40 degrees Fahrenheit. If your fridge goes above 40 degrees, your food will spoil more quickly, but if the temperature is too low, the vegetables in your drawer will freeze.
Often, crisper drawers will have a mechanism to regulate how much moisture flows into and out of the drawer. Depending upon which vegetables you are storing, set the drawer to either let moisture out for drier veggies or keep moisture in for vegetables that need the humidity. Having a fridge with multiple crisper drawers is helpful in storing vegetables based upon their humidity needs.
Vegetables tend to be very sensitive to ethylene, a substance that comes from most fruits and a select number of vegetables. Because of this, storing fruits and vegetables separately is advised. Ethylene exposure is responsible for carrots turning bitter, the yellowing of certain green vegetables and lettuce turning brown. In addition to absorbing ethylene, some vegetables also absorb odors from other veggies. For example, the odor of apples is absorbed by carrots, cabbages and onions. If odor absorption occurs, it can affect the taste of the vegetable. Add a box of baking soda to the crisper drawer to help with odor absorption. After about two weeks, you'll want to shake out the top layer of the baking soda to maximize freshness.
Some vegetables benefit from being stored in a bag in the refrigerator rather than being out of a bag. These vegetables, such as artichokes, broccoli, cauliflower, cabbage and eggplant, should be placed in the crisper bin in perforated plastic or paper bags so that they can maintain moisture. However, some vegetables like lettuce don't do well with lots of moisture; for this reason, you should not wash your vegetables before storing, but before eating instead. With carrots, beets, radishes and parsnips, removing their tops prior to storage will help them keep longer. Similarly, the head of celery stalks should be covered before storing.
Refrigerators Logo
how to install window XP without floppy disk on asus P5RD1-VM
Hi sheikhun, just ignore windows F6 to add special SATA drivers. Install windows, when finished use your Asus CD and install missing drivers from CD. Than run windows updates.
You should not have a problem, if while in your bios your SATA drive is shown in the main menu. Than check the Boot section of bios. The boot order should be.
CDROM drive 1st. SATA drive 2nd.
Disconnect any other hard drives data cable while installing windows. When you finish installing windows & installing the drivers from the CD & windows updates you can shut down the PC & reconnect the data cables you may have disconnected.
If your bios does not see your serial ATA SATA drive than your SATA onboard controller is defective. Return to Asus for replacement/repair.
Mike
Mar 30, 2008 | ASUS P5RD1-VM Motherboard
2,654 people viewed this tip
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
