Tip & How-To about Fuji FinePix A360 Digital Camera
Fuji Finepix a360
If having trouble downloading the photos to via USB (from the camera to a PC)
1) Camera to be on viewing mode
2) Clock the Menu/ok button to display the menu
3) Find the blue screen titled OPTION
4) Select the "Set-up" by clicking the Menu/Ok button
5) Select option #4
6) Select "USB MODE" and click the "Menu/Ok" button
7) Choose the icon that looks like a square with a curved bottom
8) Click the "Menu/Ok" button
...you are set!
cadman4u@yahoo.com
Fuji FinePix A360 Digital Camera Logo
I do not know how to set the time stamp for my FUJIFILM S1500. The date appears on the display screen when I view the pictures I have taken, but no longer appears once I download them to my computer??
The Fuji FinePix S1000FD camera supports time stamping only when printing pictures via USB with a printer that supports PictBridge. Otherwise, you will need to download the images and use an application such as "Visua Photo Time Stamp."
To print with PictBridge,
  1. Connect the camera to the printer and make sure the printer is on.
  2. Press the right-pointing arrow and hold for a second or until the USB logo is displayed on the camera
  3. Press the DISP/BACK button on the camera
  4. On the menu, select the PRINT WITH DATE option and press MENU/OK.
  5. Press MENU/OK again to start printing.
May 04, 2011 | Fuji FinePix S1000FD Digital Camera
how do i transfer pictures to my memory card
Connecting the camera to a PC
1. Turn the PC power on.
2. Turn the camera power on.
3. In any mode other than Voice Recording mode, press
the MENU button.
4. Press the LEFT/ RIGHT button and select the [SETUP]
menu tab.
5. Select the [USB] menu by pressing the UP/ DOWN
button and press the RIGHT button.
6. Use the UP and DOWN buttons to select
[COMPUTER], and then press the OK button.
7. Press the menu button twice and the menu will disappear.
8. Connect the PC and the camera via the USB cable.
- Insert the small plug of the USB cable into the camera USB connection terminal.
- Insert the large connector of the USB cable into the USB port of the PC.
- The plugs must be firmly inserted.
note: driver for a40 must be installed in your computer.
you can get it here.
Jan 09, 2009 | Samsung Digimax A40 Digital Camera
upload fotos
Here's how...
  • Starting PC mode
If you connect the USB cable to a USB port on your PC and then turn on the power, the camera will automatically switch to "computer connection mode".
In this mode, you can download stored images to your PC through the USB cable.
The LCD monitor on the camera is always turned off in PC mode.
  • Connecting the camera to a PC
1. In any mode, except Voice Recording mode, press the Menu button.
2. Press the LEFT/ RIGHT button and select the 'SETUP' menu tab.
3. Select the 'USB' menu by pressing the UP/DOWN button and press the RIGHT button.
4. Use the UP and DOWN buttons to select 'Computer', and then press the OK button.
5. Press the menu button twice and the menu will disappear.
6. Connect the PC to the camera with the USB cable.
  • Downloading stored images
You can download the still images stored on the camera to your PC's hard disk and print them or use a photo editing software to edit them.
1. Connect the camera to your PC with the USB cable.
2. On your computer's desktop display, select 'My Computer' and double click 'Removable Disk' - 'DCIM' - '100SSCAM'.
3. Select an image and press the right mouse button.
4. A pop-up menu will open.
Click the 'Cut' or 'Copy' menu.
- 'Cut' : cuts (i.e. moves) a selected file.
- 'Copy' : copies files.
5. Click a folder where you want to store the file on your PC.
Don't forget to rate this solution once you've tried it !
Good Luck.
May 20, 2008 | Samsung NV3 Digital Camera
help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Deleting unwanted pictures
I have two suggestions. First, you can tag a bunch of your photos on the camera, and then delete them in one operation. You can also delete all the photos on the camera in one operation. This is explained in the owner's manual on page 45 (can be downloaded from www.samsungcamera.com): Deleting images 1. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button. [Select] : Selection window for an image to delete is displayed. - Up/ Down/ Left/ Right : Select an image - Zoom T Button : Select the image for deletion. (V mark) - OK Button : Press the OK Button to display the confirmation message. Select the [Yes] menu and press the OK button to delete marked images. [All Pics] : Displays confirmation window. Select the [Yes] menu and press the OK button to delete all unprotected images. If there aren?t protected images, all the images are deleted and a [No Image!] message will display. 2. After deletion, the screen will be changed to the play mode screen. My alternative suggestion is to use a better program on your PC for downloading and organizing photos. You can get a really nice (and free!) one at www.preclick.com. When you download photos using this, it gives you the option of deleting the downloaded photos from the camera at the same time.
Apr 07, 2007 | Samsung Digimax i6 PMP Digital Camera
2,795 people viewed this tip
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
