Tip & How-To about Roland TD20SX V-Classic Electronic DRUM ESSENTIALS BUNDLE
TD20 backing voice plays on everything no matter what...
No matter what pad i hit the slapbass wave sound would play..
i unplugged all midi connections..
i turned the backing parts volume down..
i removed all my patterns from the kit...
i did a factory reset...
and there it was STILL!! dang it!!
after calling Roland and hearing they have never heard of this problem before
i took the unit apart and removed the backup battery.
( didnt want to send my unit off..omg i am broke enough.)
i also pulled the ribbon cables from their holders and and then i put everything back...it factory reset when i turned it on..
(yes i had myown personal backups beforehand)
BooM! Mr TD20 was back without that slapbass wave! yahooo!
i dont know what caused it, but i was doing some major midi routing
experiments with my comp thru Sonar6P, midiman 4x4, and my Roland VSynth...and it did just kind of show up at some point when i had the backing voices turned down i guess..
it still persisted even after the TD20 was turned off for a day and half and i turned it back on to see if it still was happening...yep, i was hoping it would fix itself..lol..i hope this helps fellow musicians..play on!!
Roland TD20SX V-Classic Electronic DRUM ESSENTIALS BUNDLE Logo
while using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they recommend using to connect the SR-18 with an electronic drum kit, but I thought as I already have the DTXplorer module I might as well use that and save the money. So far I have tried connecting my SR-18 using the MIDI OUT on the DTXplorer and MIDI IN on the SR-18. This worked great while I played the Hi-Hat, 1st Tom, 2nd Tom, Crash and Ride cymbals. However the Snare, Kick and 3rd Tom trigger no sound at all when struck. I thought perhaps it's because a MIDI cable only has 5 pins so it only allows 5 sounds to be triggered by the pads ( If this is rediculous it's because I'm an enthusiastic novice learning as I go :) ). I will be grateful for any help that someone can offer me.
you need to determine what midi note the DTXplorer is using for the snare, kick and 3rd tom, and set the SR-18 accordingly, or vica-versa. the midi notes for each instrument has to be the same.
if you cannot change the midi note in either unit to make them correspond, you can download a "midi mapper" program (i think e-drum might be one), there is freeware available if you search CNet. with a midi mapper program, you would have to get a midi/usb adapter for your computer and rouite the midi signal through a computer. midi mapping software allows you to change the midi note, when the hardware itself is incapable of doing so.
Mar 09, 2011 | Yamaha DTXtreme III Drum Trigger Module
how can i play BUP 06PK61 frm yamaha I425 on PC
how can i play .bup file in computer?
ok here is the solution!!!!!!!!
    • we should have a mic pin and audio cable as shown in this pic
    connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
    now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
    now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
Jan 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
My acoustic guitar sounds choppy when played back.
Try Using A Condenser Mic Or Making Sure That Your Phantom Power Is Turned Off When Using A Regular Mic.\www.Myspace.com/CrossRoadsToNowhere2007
Nov 06, 2008 | Boss Micro BR Digital Recorder
1,601 people viewed this tip
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
