Tip & How-To about Pepper Stuff Card Counting - [ BlackJack Teacher Pro +HD ] - Learn to Count Cards
Example: How to chshort cut keys mp3/4 avi etc 1 button pushed all put in the 1 sweet folder ange your mp3 player background
Menu/media player/press f3 short cut top keys alls done enjoy
Pepper Stuff Card Counting - [ BlackJack Teacher Pro +HD ] - Learn to Count Cards Logo
Asus N73SV-FHD-TZ087V
Your description is glare.Waht means funtion keys? Shorcut = right click WMP on the Start Menu and "sen to the desktop"
Apr 30, 2012 | ASUS N73JQ-A2 I7-740QM Notebook
hi i have the asus n53jg laptop. absolutly amazing laptop cant nock it i just have a little problem that i want to get sorted see the laptops function keys that run along the top have shortcuts on them like f10 and others how do i get them to work because i dont get anything when i press them.
The function keys that you have works alone and in combinations. You can press and hold Fn key then tap on any of those keys to get the short cuts. You can also press and hold Alt key and any of those to get another short cut. It actually depends on what you want to do.
For example:
Using single key:
F5 - it will refresh a window
F11 - try it in internet explorer to see the result
Using Combination:
Alt + F4 - it will close an open window
Fn + F3 - it will lock or disable your touchpad
I hope I understood your concern and helped. Goodluck
Jul 17, 2011 | ASUS Computers & Internet
can i unlock my philips dvp3005 dvd player
Heres how
- Press "System Menu" key to enter Set Up menu.
- Move to "Preference Page" using arrow keys to the left or to the right.
- Press the following sequence in the remote control: 135566
- A menu indicating "Region Code" will appear.
- Change region using arrow keys to top or down. Region Code = 0 will play all regions.
- Press "System Menu" key to exit Set Up menu.
Enjoy
Jun 27, 2009 | Philips DVP-3005 DVD Player
sync problem sometimes works and sometimes doesn't
I used Windows Media Player 11 to move music to my Fuze.
  1. Plug your Fuze into an USB port on your computer using the provided adapter cord. Windows will detect the Fuze and install it if need be.
  2. Once Windows has done its thing, open WMP11 and select the "Sync" tab.
  3. You can now drag and drop your music from your Library on the left to your Sync Playlist on the right.
  4. Once you've moved your selections, click on the "Start Sync" button at the bottom of the right side.
  5. The music will be uploaded to your Fuze.
You can have WMP11 detect your music and put it into your Library by pressing the F3 key. Press F3, navigate to your music folder with the Add button, and then press OK. You can remove folders from the list in the same manner.
Feb 04, 2009 | SanDisk Sansa Fuze MP3 Player
Keyboard F1 to F12
F1 - F12 Function Key Usage
Printer Friendly Version
F1:Help. Click F1 Key can load the help file of the program.
F2:Rename. Select a folder or file, click F2 to rename it.
F3:Search. On desktop, click F3 to load the search form.
F4:In Internet Explorer, click F4 will list the URL Address field.
F5:Refresh. Use it to refresh the web page in Internet Explorer.
F6:In Internet Explorer, click F6 will jump to address bar.
F7:It can be used to insert ^C in command prompt.
F8:When windows startup, it can load the startup menu.
F9:In Windows Media Player, it can increase the volumn.
F10:In Windows Media Player, it can decrease the volumn.
F11:In Internet Explorer, click F11 will switch to Full Screen mode.
F12:In MS-Word, it will show out the "Save-As" dialog.
Take this link u will get all the Function Keys description
http://www.computerhope.com/issues/ch000306.htm
Aug 31, 2008 | Computers & Internet
569 people viewed this tip
Top Pepper Stuff Apps Experts
Lesley Cameron
Lesley Cameron
Are you a Pepper Stuff App Expert? Answer questions, earn points and help others
