Home | All Products | R52WH73 Television | Tips
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
willtab
By Guru willtab
Rank: Guru
Rating: 90%, 754 votes
posted on Sep 20, 2008
Very Helpful
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
6. REPLACE FUSE RCA PART 259213
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
Comment by willtab, posted on Sep 20, 2008
NEVER OPEN BACK OF SET OR ATTEMPT ANY REPAIR WITHOUT FIRST UNPLUGING SET
Comment by willtab, posted on Jan 15, 2009
Very important..... Remember to solder the flyback connection. I have seen this set come back to the shop every time if i didnt resolder these connections.
Was this helpful?
Yes
No
33 people thought this was helpful
Comment #1
posted on Nov 07, 2009
kilroywzhere
By Apprentice kilroywzhere
Rank: Apprentice
Rating: 0%, 0 votes
willtab,
You are the man! I printed out your instructions. Went to RadioShack got a in line automotive fuse holder # 270-1238 and fuse # 270-1047 (500 milliamp, they didn't have 400 in stock). Soldered it in place and touched up the flyback and WAM! it worked like a champ. Total cost.... $6.06 unbelievable! You made me look like a hero! My wife thought for sure the t.v. was done for. Thanks for saving my ****!
kilroy
Comment #2
posted on Oct 27, 2009
j_prosper
By Apprentice j_prosper
Rank: Apprentice
Rating: 0%, 0 votes
I replaced the FL231 fuse on my RCA HD52W66 it works ok now but, my remote is not working the LED lights work but not controlling my TV . what did I do wrong and what can I do to fix this?
Comment by j_prosper, posted on Oct 28, 2009
does anybody have a solution to my problem that I posted below?
email me if you do.
j.prosper@hotmail.com
Comment #3
posted on Oct 01, 2009
lallison21
By Apprentice lallison21
Rank: Apprentice
Rating: 0%, 0 votes
thank you! this helped so much! saved us so much money and our tv works like brand new. thank you!!
Comment #4
posted on Aug 20, 2009
splatman
By Apprentice splatman
Rank: Apprentice
Rating: 0%, 0 votes
Chalk up another successful repair thanks to your instructions, willtab! Quick, easy and saved a buttload of money!
Comment #5
posted on Aug 15, 2009
CaptFDU
By Apprentice CaptFDU
Rank: Apprentice
Rating: 0%, 0 votes
This is a great article. I have replaced the fuse and re-soldered the flyback connections. When I plug the set in, I get the power light on the front of the TV comes on and then in about 2 sec it goes off and i hear a beeping sound that I think is coming from the flyback. This happens 3 times and then nothing. I see someone else has the same problem and I was wondering if there is a fix. Thanks in advance for any help possible...
Comment #6
posted on Jul 08, 2009
kc8iaq
By Apprentice kc8iaq
Rank: Apprentice
Rating: 0%, 0 votes
Thank you so much for this helpful information. I studied your information and it was easy to follow the directions for repair. I was able to nibble a portion of the plastic away with my dykes to allow the easy removal/replacement of the bad fuse. I re-soldered the flyback transformer connections, and installed the new fuse. The TV has been working great now for over a month so I have to say that that the problem was fixed correctly. It saved us big bucks! And it convinced me to sign up here at fixya.
Big thanks to ya willtab! hope I can return the favor.
Sincerely - kc8iaq
Comment #7
posted on Jul 02, 2009
vancortt
By Apprentice vancortt
Rank: Apprentice
Rating: 0%, 0 votes
We installed using your instructions and the convergence problem is fixed. However, now everyone is blue. Did we do something when we installed?
Comment #8
posted on Jun 30, 2009
tomhasi
By Apprentice tomhasi
Rank: Apprentice
Rating: 0%, 0 votes
do i have to worry about getting zapped when resoldering the flyback transformer pins? Is it recommended to discharge the flyback first or should this not be of my concern?
Comment #9
posted on Jun 27, 2009
Stonestorm
By Apprentice Stonestorm
Rank: Apprentice
Rating: 0%, 0 votes
I see you're not short on accolades, but here's one more. Though I would like to ask a small question.
After reading all you've posted on this bug, I used my DVM to check the condition of FL231, and well, got continuity, < 1 ohm. But the problem persisted. So..... being daring, I very carefully shorted the fuse legs with a clip lead and this resolved the problem. I sat in front of the TV for a while to make sure any built-in-smoke wasn't going to escape. After a half hour, I felt safe leaving it that way until my digi-key order came in. ( I lost the PN I had written down and threw away the packaging, but the same fuse can be easily found on digi-key with a little bit of searching.) Replaced the fuse today and everything's back to normal. I also resoldered the flyback transformer pins like you suggested. Thank you for this priceless knowledge you shared with me :o)
Comment #10
posted on Jun 09, 2009
lowtech130
By Apprentice lowtech130
Rank: Apprentice
Rating: 0%, 0 votes
Hi I am having the convergence problem with the rca 52" projection. I checked continuity for the
FL231 Fuse and it tests fine. I soldered the flyback even though that looked ok as well. I now have the convergence option back on the tv but when you do he auto convergence the picture is still rainbowed. I i try to manually align the colors the cross hair target lines up but the words below arent fixed. If I try to eyeball it with the words then the cross hair is way off. Any ideas?
Comment by lowtech130, posted on Jun 09, 2009
Comment #11
posted on Jun 03, 2009
tube type
By Apprentice tube type
Rank: Apprentice
Rating: 0%, 0 votes
willtab,
Thank you for the advice. Just fixed my 3-year old Walmart RCA HD52W59 following your procedure. I didn't figure our how to tip the board tray untill I was finishing. I was sliding the tray to its travel limits and trying to lift. I removed the board from the tray instead of lifting the tray.
I used my trusty RCA WV-38A (a kit I assembled in 1964) to check fuses and diodes. The 400 ma fuse was the only problem found.
Vacuumed all I could get to and cleaned out all of the carbarized household dust around the high voltage I could reach with a small brush. Resoldered the flyback as you advised. Received the fuse today and the set is operating perfectly as I write. I ordered extra fuses because my daughter has one of these sets from Walmart and I think this will repeat. The high voltage stuff at the CRT's that I couldn't reach worries me.
Thank you for passing on the right stuff.
thermionic
Comment #12
posted on Jun 02, 2009
onemanshow
By Apprentice onemanshow
Rank: Apprentice
Rating: 0%, 0 votes
Thank you so much. You save me alot of money. Somewhere in the process I messed up and now my remotes won't work.
Comment #13
posted on Jun 01, 2009
sueecsi
By Apprentice sueecsi
Rank: Apprentice
Rating: 0%, 0 votes
Thank- you so much. Sears was going to charge us $200 to replace this fuse and we were able
to fix the tv ourselves with your easy to follow instructions. I hope you know how many people
you have helped and how much money you have saved us as well.
Comment #14
posted on May 23, 2009
magic_ch89
By Apprentice magic_ch89
Rank: Apprentice
Rating: 0%, 0 votes
Thank you! I replaced the fuse with the part number you gave. It was $3 plus another $7 to ship (I don't understand that, but what the heck, $10 to fix my TV) I re-soldered the flyback as some of the soldered connections were obviously discolored. I also took your advice and cut a notch in the plastic brace so I didn't have to take the board out. It worked like a charm. Thanks again.
Comment #15
posted on May 04, 2009
benandmich79
By Apprentice benandmich79
Rank: Apprentice
Rating: 0%, 0 votes
Thank you so much for this information. We were able to fix the problem for less than $10. Found the part on E-Bay and received it fairly quickly. Was easy to replace following your guide. And I did resolder the flyback connections as well. Works great!!! Thank you very much. You are a guru!
Comment #16
posted on May 01, 2009
deajohns
By Apprentice deajohns
Rank: Apprentice
Rating: 100%, 1 votes
This is great step by step, and it makes sense, but the problem is that I have a P52960 52" dated 2003, and I can't find the fuse that you're talking about. The only fuse I can find is F2401, right next to the 115VAC power cord. I found the flyback, looked to the right and still just the regular bus style fuse. Any idea if this model has the FL231 in another location or if the bus fuse replaced/was replaced by the FL231?
Thanks for any help you can give,
Devon Johnson
Comment #17
posted on Apr 24, 2009
staure
By Apprentice staure
Rank: Apprentice
Rating: 0%, 0 votes
Where can you find this part at? Does it have to be ordered online?
Comment #18
posted on Apr 22, 2009
donshaye1986
By Apprentice donshaye1986
Rank: Apprentice
Rating: 0%, 0 votes
Thank you so much for this article. My husband and I where able to fix our tv and now the picture is better then when it was new.
I love this website and thank God for the internet :-)
Thanks sooo much again
Comment #19
posted on Feb 28, 2009
chevyluvn
By Apprentice chevyluvn
Rank: Apprentice
Rating: 0%, 0 votes
This fix was too easy thank you for posting this. I got this tv from a friend that didnt want to pay the $400 she was quoted to fix it then i found 2 more just like it on the curb so now i have 2 working and 1 for parts and it didnt cost me a dime!!!!! thanks again
Comment #20
posted on Feb 23, 2009
chikid68
By Apprentice chikid68
Rank: Apprentice
Rating: 0%, 0 votes
this article really helped and be sure to resolder all the connections on the transformer I didn't and the fuse blew again in just a couple weeks but this does work great.
my neighbor gave me his old rca because he didnt have the 400 or so to put it in the shop and after I found this page and fixed it for under ten bucks .
Boy was he mad lol
Comment #21
posted on Feb 19, 2009
DrjRepair
By Apprentice DrjRepair
Rank: Apprentice
Thank you very much, I replaced the fuse and it blew again. If I did not read your comment I would of replace the fuse again. I called the Television Tech., he said I had to bring it in. Well I know now that I should try to resolder before replacing the Fuse. If I did not see your message I would of drove the television 200 mmiles to the shop. THANK YOU VERY MUCH.
Comment #22
chrish414
By Apprentice chrish414
Rank: Apprentice
Rating: 0%, 0 votes
Hello I read ur answer to the Fl 231 fuse problem in rca projection tvs. I have now actually replaced the fuse 3 times and it just blew again. Every other time i just lost the option in the menu and the screen bowed with the colors separating. this time its the same except that when it first happened it shut the tv off and tried to come back on 2 or 3 times unsuccessfully till i turned it off and waited now it comes on but i have the convergence problem. the tv is about 2.5 years old and blew the first fuse then the 1st replacement lasted about a week and a half. 2nd rep a few days and the most recent about 2 days. I have one more replacement left and wanted to check with you to see if theres anything you could maybe tell me as to the problem.
Thanks for your time, Id appreciate any help.
Comment by chrish414, posted on Feb 19, 2009
By the way my email address is chrish414@gmail.com
Comment #23
posted on Feb 11, 2009
wireguy101
By Apprentice wireguy101
Rank: Apprentice
Rating: 0%, 0 votes
Do I need to discharge anything before I start taking the blown fuse off, or do I just need to make sure I try to stay away from the red wire.
Comment #24
badmad
By Apprentice badmad
Rank: Apprentice
Rating: 0%, 0 votes
I gotta tell you...oh boy... you saved me a bunch of money. Right now the U.S. economy sucks and thanks to Mr. Bush! (Mr. ******** to me). Been able to fix stuff myself is a pretty good damn deal right now. After following your instructions, well, I got my TV set working properly again. I'm so proud of myself and have no words enough to thank you. I'd never did soldering before and with an old PC mother board to trainning myself, I got it done! Advise: When you buy a soldering kit, please, also buy a desoldering kit. It makes much eisier. Once again, THANK YOU!
Comment #25
posted on Jan 14, 2009
ekimatled
By Apprentice ekimatled
Rank: Apprentice
Rating: 0%, 0 votes
Good day!!!I i had problems with the fl 231 fuse on my RCA D52W23 proj.tv....i was able to buy the rCA part 259213 and replace it.i followed all your suggestion...it worked fine for a day but all of the sudden in the middle of a show i was watching the tv turned off and when i turned it on again the"convergence" problem is back: e.g convergence option is missing again, the red, blue,green shadows are appearing again, the bowing effect on the top and bottom of the screen...where did i go wrong
Comment #26
posted on Jan 10, 2009
nmurphy93
By Apprentice nmurphy93
Rank: Apprentice
Rating: 0%, 0 votes
I was able to fix my moms rca using these instructions. She is on a very limited income and the TV repair wanted $200 plus to fix. Also wanted us to haul the tv to them. My brother-in-law is an electrican and he was able to fix for 98 cents. This is a great site. Thank you!!!!
Comment #27
posted on Jan 08, 2009
becaulder
By Apprentice becaulder
Rank: Apprentice
Rating: 0%, 0 votes
Willtab, Thank you for the tip IT WORKED. $550.00 quote to fix - 3.95 fuse - 7.95 UPS charges = a savings of $488.10. Didn't even remove the board, just tilted up and soldered from underside. THANKS AGAIN
Comment by becaulder, posted on Jan 09, 2009
538.10 saved had 500.00 on my mind.
Comment #28
posted on Dec 22, 2008
pontiac2m8
By Apprentice pontiac2m8
Rank: Apprentice
Rating: 0%, 0 votes
So how would one ensure that all the electricity has been discharged prior to operating on it?
Comment #29
posted on Dec 04, 2008
cobjones
By Apprentice cobjones
Rank: Apprentice
Rating: 70%, 1 votes
Wiltab, thanks for all the help, I got a quote of over $250 bucks to fix this problem. Instead I went to Radio Shack and picked up a soldering kit for $10... what a life saver.
I do have another question I will shoot you. The digital tuner also went out on the same tv. It is also removed from the options menu. I would figure it is a fuse as well???? Any help would be appreciated.
Comment #30
posted on Nov 21, 2008
mitrestre
By Apprentice mitrestre
Rank: Apprentice
Rating: 0%, 0 votes
worked perfect got a part for under 4 bucks soldered it in place and works great! Thanks for the tip and tricks section very helpful.
Lee
Comment #31
posted on Nov 19, 2008
sboans
By Apprentice sboans
Rank: Apprentice
Rating: 0%, 0 votes
I replaced the fuse and the tv worked for nearly 20 minutes then it blew again. Luckly I bought spare fuses to replace but before I put in another one I need some clarification. Am I to understand the reason the fuse blows is because of the flyback? And if this is the reason do I just need to add solder to the existing flyback or do I need to remove all the old solder and then add all new solder? Once again the fuse did fix the t.v. but only shortly and I need to know what is blowing the fuse.
Comment #32
posted on Nov 18, 2008
kputens
By Apprentice kputens
Rank: Apprentice
Rating: 0%, 0 votes
willtab,
You were right on the spot with this one !!!! Purchased the part on line at parts.com for 3.75 ea took less then 30 min to fix. Much better then the $500.00 I was quoted from repair places.
Thanks Karen
Comment #33
posted on Nov 14, 2008
wayfastytee
By Apprentice wayfastytee
Rank: Apprentice
Rating: 0%, 0 votes
looks to be R52wh77yx58 or 50 does that # ring a bell. this is the main board where the fuse fl231 is located bottom left board right when u take off the back. if so please email me @ gixrsixr@gmail.com thanks. also what do these run around? i cant even see the part on rcas website.. please email me with wherere i get this board used or new . after trying to replace teh fuse it wont even power on/ green light comes on and flashes 3 times. guess that means its showing a short somewhere. what does a new board run around for this i cant find it anywherere cause i dont know the part # or where to even look. i could really use the help. my tvs been collecting dust for over a year now. and im still making payments to bestbuy on a broken tv and they wont help me.. agaian my email is gixrsixr@gmail.com easiet way to help me is to email me..thanks you
Comment #34
posted on Nov 08, 2008
mtwoman
By Apprentice mtwoman
Rank: Apprentice
Rating: 0%, 0 votes
I just want to thank-you for this info. I was ready to trash my tv. I wrote RCA and cussed them good,too. I read a bunch of other articles and everybody had a different solution to the convergence problem. But yours made the best sense. So I lifted the circuit board out and jumped the two solders with some alligator clips to test the fl213 fuse and voila it works. Now I'm off to get me a new fuse and will resolder the flyback as suggested. I also cut off the plastic as you suggested so I could get access to it as it was a lot easier than taking the whole board out. Again, Thanks!
Can you Help with these Projection Televisions problems?
RCA R52WH73 Television
The picture on my RCA HDTV R52WH74 flipped out. The red,...
picture bowed with double image. How do we fix this?
The screen is saying searching for channel and I cannot...
Green Light comes on but no picture or sound
the power will not work does it need a g link. because...
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
