Tip & How-To about Cell Phones
Nokia secret codes
Here i have some secret codes for Nokia phones: On the main screen type: ¤ *#7780# : reset to factory settings. ¤ *#06# for checking IMEI (International Mobile Equipment Identity). ¤ *#67705646# : this will clear the LCD display (operator logo) ¤ *#0000# : to view software version. ¤ *#2820# : bluetooth device address. ¤ *#746025625# : sim lock allowed status. ¤ *#62209526# : display the MAC address of the WLAN adapter (this is available only in newer devices that support WLAN like N80) ¤ #pw+1234567890+1# : shows if sim has restrictions. ¤ *#92702689# : takes you to a secret menu where you can find the informations below: 1. Displays serial no. 2. The month and year of manufacture. 3. Displays (if there) the date when the phone has been purchased (MMYY). 4. Displays the date of last repair (if found) (0000). 5. Shows life timer of phone (time passes since last start). ¤ Enhanced Full Rate codec (EFR) activation. Increases signal strength, makes the signal reception better. It is also helpul in using GPRS when the service is not responding or working too slow. (note: phone battery will drain faster though). ¤ *#3370* : EFR deactivation. Phone will automatically restart. Battery life will increase by 30% because the phone will now recieve less signal from network. ¤ *#4720# : Half Rate Codec activation. ¤ *#4720* : Half Rate Codec deactivation. The phone will automatically restart. If you forgot wallet code for Nokia s60 phone, use this reset code: *#7370925538# (note: your data in the wallet will be erased) phone will ask for lock code (the default lock code is 12345). Press: *#3925538# to delete the contents and code of wallet or type: *#7370925538# on the main screen. This resets wallet code but you will lose all stuff in the wallet. ¤ *#7328748263373738# : resets security code (default code: 12345). ¤ Unlock service provider: insert sim, turn the phone ON and press volume up(arrow key) for 3 seconds, should say "pin code'', press ''c'' then press *. Message should flash, then press * again and 04*pin*pin*pin# change closed caller group (settings>security settings>user groups) to 00000 and your phone will sound the ''message tone'' when you are near a radar speed trap. Setting it to 500 will cause your phone to set off security alarms at shop exits ( works on some nokia phones)
Cell Phones Logo
FLASHPLAYER
Please uninstall and install the flash player or can reset factory setting.
RESET NOKIA FACTORY SETTING
First Try it:
You may try default phone and security code to remove it
Defalt phones codes is 12345 or 00000 you can use it
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3"
"green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory
stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate and leave a short comment,that is your choice.
Hope this helps.
To check the phones Software revision for Nokia Mobile.
On the main screen type *#0000#
To enter in the secret menu in Nokia Phone.
On the main screen type *#92702689# [*#war0anty#]
It will take you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
To restore Factory Settings for Nokia mobile
*#7780# reset to factory settings.
Taking picture without getting noticed.
Turn on/off the "click" sound made by the camera by selecting the 'Silent' profile or by turning warning tones on/off.
Hiding your Mobile/ Cellphone Number
Go to: Menu > Tools > Settings > Call > Send My Caller ID >
'Yes', 'No' or 'Set By Network' to follow the default settings of your home network.
It works only with very few network who provide you facility of "Private Number"
Speed Dialing From Simcard contact (not stored in mobile phonebook)
Type number followed by # then call.
Example: 1# or 2# or 21#
Jan 24, 2011 | Nokia E71 Smartphone
lost cecurity code
Yesterday after searched around, finally i found a site contains codes for all type Nokia phones, such as: latest firmware, unlock, security code, hidden secret, and more.
If you need, can find them here: http://nokia-tricks-codes.blogspot.com
For all Type Mobile Phone here : http://mobile-secret-codes.blogspot.com
Or check this also
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Thanks.
Jan 05, 2009 | Nokia 1600 Cellular Phone
i want to codes
LG SECRET CODES:
LG all models test mode: Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI (ALL): *#06#
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Simlock menu (LG B1200): 1945#*5101#
Simlock menu (LG 510W, 5200): 2945#*5101#
Simlock menu (LG 7020, 7010): 2945#*70001#
Simlock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select 'SW Ver.info'
Code to reset phone :
- Phone without SIM
- Select 'Factory Reset'
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*#
MOTOROLA SECRET CODES
IMEI number:
*#06#
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
NOKIA SECRET CODES:
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that supports WLAN like N80
Dec 13, 2008 | Nokia 5200 Cellular Phone
2,446 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
