Tip & How-To about Refrigerators
Switching door opening direction in Tadiran Appolo 103
Even though in the support I was told that in that specific model there is no way to change the door opening direction, I manged to switch it. The door handles are now useless and confusing, but overall the fridge is ok.
Refrigerators Logo
Hello, I replaced a worn out garage door motor with a new craftsman model. The door try's to travel down when the opener is pushed, even though the door is fully closed. I'm no garage door expert, but It appears as though the traveler was not set in the proper position ? Help Please
Yes, reread the directions travel needs to be set for both up and down, and MUCH MORE IMPORTANTLY the safety settings must be set. This allows the door to close on a foot and not cause damage....VERY IMPORTANT to set correctly....
Apr 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener moves about 8" then reverses direction before touching the limits
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. It is most likely stripped. You can purchase a new one at Sears or any good door opener company. It comes with instructions.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad will close door, but not open it!
Try changing the battery and reprogam the keypad. The code remains active for about 30 sec. after it is entered into the keypad which allows you to press enter to change direction of the door
Jan 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
neptune washer not starting
open panel at rear of control panel usning phillips head and 5/16 the board attached to that panel will probably have a burnt r14 r1 or r21 resistor. this has been an ongoing problem with this model even a class action lawsuit.(lawsuit expired 9/2005) you can change the board but this will eventually happen again maytag directs you to do a full conversion kit rebuild about $400.
Feb 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
2,564 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
