Tip & How-To about Elna Sewing Machines
Have you acquired an early Swiss Elna Sewing Machine??
There are still many of these Elna Supermatic sewing machines around and being used; they might not have all the electronic bells and whistles of a new model but they are a very well made solid metal case machine, parts can still be found and they will produce a good quality stitch and handle a wide range of fabric types.
Maintaining these early models means regular cleaning and oiling. Each time you get your Elna out to sew you need to remove the needle plate and open up the bobbin cover, take out the bobbin then using a little brush carefully remove all lint and fluff that you can see from the race, around the feed dogs and in the surrounding area. Your model may have marked red dots for oiling points, usually one in the middle of the bobbin holder, and often another red dot nearby in the race area. Plus a couple on the body area sometimes or top of the machine. Oil these marked points with a drop of good quality clear sewing machine oil when you get the machine out to sew, especially into the bobbin holder, then run the machine slowly without a bobbin or thread for a few seconds to spread the oil through the moving parts.
Use Swiss Elna metal bobbins only, they are very distinctive and only have holes on the top with a smooth underside and are slightly dished. Always wind the bobbin with holes on top and load it into bobbin holder same way; this way you always have the thread coming off the bobbin in the right direction.
It is important to always click the bobbin thread into the tension spring on the outside of the bobbin holder, there is usually an audible sound as you get it into tension. Just hold the thread tail with one hand and pull it around into the groove on the outside of the bobbin case, then put a finger onto the bobbin to hold it still, and push down on the thread tail with your index finger to push it down into the tension spring, you should hear it click in. Lift the thread tail vertically to check, the thread wont come out if its in fully.
Whenever you start a new seam ALWAYS hold the two threads at the back of the needle plate firmly as you start stitching until you've completed 4 or 5 stitches, to keep them clear of getting pulled back into the bobbin race. This saves those horrible jam ups happening when you start a seam.
Change your needle regularly to ensure it is sharp and use the right sized needle and type for the fabric you are sewing; these machines take the standard 130/7H needle system, and always install flat shank to the back of the needle bar.
Happy sewing on your vintage Elna.
Sewing Machines Logo
walking foot for 1963-1964 elna supermatic
try a elna dealer
sewingpartsonline.com
sew4less.com
May 15, 2012 | Elna Sewing Machines
how do you put a bobbin in a elna so i can use it to sew
Drop in a full bobbin with the holes side upwards (I'm assuming this is a Swiss Elna sewing Machine horizontal bobbin design as you haven't given the model number).
Now, hold the thread tail with your right hand and pulll the thread clockwise towards you while holding the bobbin still with a finger from your left hand. Bring the thread tail around towards you until it goes into the little slot, then press downwards onto the thread tail close to the bobbin until you hear it click into the tension spring. Test by lifting the thread tail upwards, it should stay in tension and not come back out of the groove.
Now close the back slide cover over the bobbin leaving the bobbin thread tail visible out to the right.
Now manually turn the flywheel towards you while holding the top thread tail and take the needle down into the bobbin holder area and back to the top, pull the thread tail to bring the bobbin thread up to the top.
There is a threading up diagrams at www.sewusa.com http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
for the old Supermatic but the bobbin holder design is almost identical for all the subsequent models such as the SU, TSP, Supermatic or Air Electronics like the Stella, Carina or Jubilee, the above is the same for all.
Sep 19, 2011 | Elna Sewing Machines
I have lost my manual for my elna supermatic seger, where can I find one?
Hi Glen, not sure if you mean sewer, or serger. The Elna Supermatic sewing machine manual is available at this link: http://www.clawges.com/sewing/Elna_manual/index.html
Trust this is what you are looking for.
Sep 01, 2011 | Sewing Machines
2,653 people viewed this tip
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
