Tip & How-To about Acer Computers & Internet
How to replace a keyboard of acer laptop
How to Replace an Acer Aspire Laptop Keyboard
When you're typing on your Acer Aspire and the words suddenly stop appearing on the screen, and all the troubleshooting in the world doesn't solve the problem, the time may have come when you need to replace the keyboard. There's no need to panic. The Acer Aspire is easily disassembled. You can remove the keyboard and replace it without a problem, just as long as you're gentle with the hardware, and you refrain from damaging the motherboard, which is directly beneath the piece you're replacing.
Instruction:
1.Power down the laptop and give it some time to cool down. Ground yourself by touching an unpainted metal surface while you wait (you don't want to introduce static into the internal components of the computer).
2.Fold the LCD screen backwards so that it's flat like the keyboard.
3.Use your flathead screwdriver to lift the piece directly above the keyboard that has the "Power" button and other commands on it. Once it's lifted, you can take it off with your hand.
4.Remove the screws above the "F5" and "F10" keys with a Phillips-head screwdriver, and put them in a place where they won't be lost.
5.Lift the keyboard away from the laptop, but don't pull it too hard because it's still attached to the motherboard by a ribbon.
6.Use your fingers to push out the tab that secures the ribbon to the motherboard and disconnect the ribbon from the computer. The keyboard should now be free from the laptop. Put it to the side and get the replacement keyboard.
7.Insert the ribbon into the motherboard, and close the tab to secure the ribbon.
8.Lay the keyboard down in the laptop so that the screw holes line up. Replace the two screws that you removed in Step 4.
9.Use your hands to replace the piece of the laptop that has the "Power" button on it. Just lay it in place, and secure it by pressing gently with your hands.
10.Fold up the LCD screen to ensure that everything is connected properly. Turn on your laptop and test the keys on your log-in screen.
Please vote for this tip if you find it very helpful. Thanks.
Computers & Internet Logo
ACER ASPIRE ONE NOTEBOOK PC-When I type the keys beep and the backspace key hesitates and makes me crazy
It looks like the laptop keyboard will need to be replaced. Go to www.ebay.com Type: make and model of the laptop and refine search to keyboard. Before you go any further double check with external keyboard.
Apr 26, 2012 | Acer Aspire One A150-1006 Notebook
i have a acer laptop and its makes these beeping noises and it doesnt stop and when i try to type it just types diffrent letters
Hello
There is a Keyboard problem and you need to remove your Laptop keyboard and try to see if the beeping is stopped. If yes then you have to replace the keyboard.
Jul 23, 2011 | Acer Aspire One PC Notebook
4,890 people viewed this tip
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
