Tip & How-To about Tablets & eReaders
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
Tablets & eReaders Logo
orders not received
Call Kindle at 1-888-280-4364 and let them know there's a problem. They'll walk you through downloading it onto your device. Make sure your tablet or reader is fully charged and working properly, with an internet connection, when you call.
Aug 12, 2014 | Tablets & eReaders
cannot connect to wifi
having problems connecting to Wi fi and not being able to get the screen to rerespond when i touch a app. i have to press to hard in order for the tablet to respond
Jan 01, 2013 | PANDIGITAL Novel Color Multimedia eReader...
velocity cruz tablet (R100 series) is frozen on startup screen that says
Give the thing to some one and purchase a new device. The processor is not operating the unit. I see no way to recover from this problem. If you remove rear cover and unplug battery you can try again and again. You can install os on micro card but it will not work. it makes a nice paper weight.
Gumper
May 13, 2012 | Velocity Micro Cruz Reader R103
i installed xp and my pen dont work
I would reinstall it as per the instructions from HP. as there may be drivers missing.
Copy attached.
Software Pre-installed Software
HP Mobile Printing for Notebooks
HP Help and Support (XP Only)
Safety and Comfort Guide
Adobe Acrobat® Reader v. 5.10
Microsoft Reader v. 2.5
Zinio Reader v.1.4
Sun Java 1.4
Windows Media Player 9 for XP
HP Tablet PC Tour
*Intervideo WinDVD Playback Software v. 4* (Pre-loaded) Recommended software/services Availability of recommended software applications or services may vary by region and may require additional purchase and/or subscription
FranklinCovey PlanPlus (30 day trial period)
MindJet MindManager 2002 for Tablet PC (21 day trial period)
Alias SketchBook Pro (15 day trial period)
Zinio (see Digital Magazine icon on Tablet PC desktop for more information)
ScanSoft Omniform Filler 5.1 and Dragon Naturally Speaking Standard Edition 7.1 (available as a special configuration) Additional software available through the web HP Client Manager Software
HP ProtectTools Smart Card Security Manager
QuickLook for the HP Tablet PC TC1100 series *NOTE: Software is loaded on the hard drive and must be installed by running the Software Setup utility. System Recovery Each unit is shipped with a recovery CD kit containing Operating System Recovery and Driver/Application Recovery CDs. These CDs allow users to either recover or repair the tablet's operating system and select drivers without losing personal data. The Operating System CD also provides the option of reinstalling the operating system software provided with the tablet.
Feb 27, 2011 | Compaq tc1100 Tablet PC
2,831 people viewed this tip
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
