Tip & How-To about Apple iPhone 3G
Frozen Iphone
If Your iphone is frozen hold the home button and the power button for about ten seconds and it will restart, make sure you press those buttons at the same time!
Apple iPhone 3G Logo
ive had my iphone for almost 2 years and my friends played a trick o me and locked my phone up to where i have no access and it tells me to hook up to itunes but it dont work.
      Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears. You may have to hold the buttons down for up to 20 seconds before anything happens. Afterwards, your device should restart and return you to the Home screen.Nov 30, 2013
      iPhone: Fix Frozen or Locked Up Screen - Technipages
      www.technipages.com/iphone-frozen-or-locked-up-screen
    Feedback
    How to Fix an Apple iPhone That Is Locked Up - Everyday Life
Jan 16, 2016 | Cell Phones
My I pad is frozen, how do I get it unfrozen
Hold the button on the back edge near the back camera lense for about ten seconds.
Sep 22, 2014 | Apple iPad 2
My IPhone has frozen and I can't even shut it down. Can you help me with this problem?
you can try the following steps
  1. Press and hold the Sleep/Wake button until the red slider appears. When you see the red slider appears, release the Sleep/Wake button.
  2. then press and hold the Home button for six seconds
if the screen is still unresponsive try to restart the iphone by following these steps
  1. To turn the unit off, press and hold the Sleep/Wake button until the red slider appears.
  2. Slide your finger across the slider to turn off iPhone.
  3. To turn the iphone on, press and hold the Sleep/Wake button until the Apple logo appears.
if restarting does not work, try resetting the iphone
1. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds or until you see the apple logo appears
if your screen becomes responsive, try to reset the settings by going to the settings of y ur iphone then general then reset and reset all. after this, restore the files on your iphone through itunes
Apr 20, 2011 | Apple Cell Phones
i reset my iphone 3g and now its been frozen for 2 days, it only shows start-up apple logo. please help!
Do a hard reset.
  1. Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
  2. Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
  3. You may let go when you see the silver Apple logo.
  4. You have completed a hard reset successfully.
  5. Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen. This is normal.
If this does not work, put into recovery mode and restore from itunes.
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
As soon as the screen goes black release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone will look like this:
Feb 28, 2011 | Apple iPhone 3G
My iphone 3gs shut off and won't turn on... tried rebooting it but saw nothing. How long should I hold the "Home" button and the "Power" button?? If this doesn't work, what should I do??Please help...
If something isn't working right, restarting, force quitting an application, or resetting
iPhone will likely solve the problem.
Restart iPhone: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPhone. To turn iPhone back on, press and
hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPhone or if the problem continues, you may need to reset. A reset
should be done only if turning iPhone off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPhone
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPhone: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
Oct 06, 2010 | Apple iPhone 3G
2,043 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
