Tip & How-To about Silverlit Toys Red Air Hogs R/C Havoc Heli Mini Electric Infrared RC Helicopter by SpinMas
Infrared RC Copters
Hi, everyone.
Ever since I saw the first advertisements on YouTube, some years ago, I wanted to acquire one of these little helis. When I finally acquired one, I had lots of fun until the little thing started to give me trouble.I own several of these mini-copters and have managed to maintan most of them in good working conditions for about 4 years now.
I would like to share some things that I have learned about RC Infrared Helis, specifically speaking, the airhogs RC helicopters.
First of all these little copters are not intended to be used outside home unless on a very calm day and on an area that has to be protected against sunlight, because sunrays interfere enormously with the IR beam with which the Infra-red light-emmiting controller communicates with the copter. I have found out that even while flying an air hogs copter indoors, when you get them close to a ray of sun shinning through a window, it suddenly drops to the ground.
Next, Most problems that I have encountered have to do with a combination of low battery power, plus trimming. In some of these copters, trimming can take a great deal of pulses before you can get them to fly right.
On the first models I would cut a cardboard fin and tape it to the front of the heli, below the nose and across form it, side to side to make it thrust forward.
Many times there were things like hairs or pieces of cobwebs attached to the axle of the back rotor, causing the heli to spin uncontrollably, even after trying to trimming it with the remote contol.
On other ocassions the copter wouldn't hold a charge even with fresh batteries on the controller. I learned that in time, the charger connector/plug may get dirty, so I usually spray the inner part of these connectors with a light coat of contact cleaner(available at any electronics store like Radio Shack) and then plug and unplug the connector a few times. This has worked fine with my older copters that have presented such problems.
Silverlit Toys Red Air Hogs R/C Havoc Heli Mini Electric Infrared RC Helicopter by SpinMas Logo
Hello all, I'm looking for a service manual for a Homelite UT10910. All your help would be greatly appreciated. Thanks.
This may not be helpful, however, you may try this book.
http://www.baileysonline.com/Chainsaw-Parts/Repair-Tools/Chainsaw-Tools/Chain-Saw-Service-Manual.axd
Depending on what you need to do, this may help.
https://www.youtube.com/watch?v=AMZlq6Z1lgA
Or, this.
https://www.youtube.com/watch?v=Z1kbFUOB5gU
Last, this website may also be helpful - the House of Homelite discussion forum. All products Homelite, experts and repair knowledge.
http://houseofhomelite.proboards.com/
Apr 21, 2017 | Homelite Garden
i Need a user manual for McCulloch pm 360 chainsaw
how old is that saw .gee
runs on steam does it ?
here is one on youtube
https://www.youtube.com/watch?v=wXKDA9_7K8A
Mar 07, 2017 | McCulloch Garden
How to change blade
If there is a button (most circular saws have a button of locking handle) loosen the blade with an allen key in the same direction as the working direction of the blade.
BUT if there is no locking facility some screwdriver a bench vise on the blade (beware not on beside the sawteeth.
or block the sawteeth with a little screwdriver against the base to lock the movement.
OR https://www.youtube.com/watch?v=cjLHqBZGFaA
How to change circular saw blade
Jan 31, 2017 | Blade Saws
hi, I'm currently on windows 10 pro, unfortanitly my partner has did something now it says I need to activate windows and put in product number again, can u help? I'm new to all this
Hii Christina,
You can contact to Microsoft Experts on 1800-102-1100.
Or, if you want Microsoft Technician for your problem you can contact on 1800-626-1046.
Thank You.
Oct 28, 2016 | Computers & Internet
519 people viewed this tip
Top Silverlit Toys Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Silverlit Toys Toy Expert? Answer questions, earn points and help others
