Tip & How-To about Video Game Consoles & Games
How to Remove DRM Protection From ITunes?
This application is compatible with most of the new and advanced Windows operating systems. All you need to do is to import a list of DRM protected songs and videos. You can select a suitably compatible and universally applicable format for these files.
DRM is short for Digital Rights Management. This is the security that aims at protecting and safeguarding the content being streamed or played via any advanced platform like ITunes. Essentially, this is the kind of protection, which is given by the access controllers of ITunes. They place certain restrictions on the files which are being played or being accessed through ITunes. It is a major concern for the software authorities that some of the downloaded content may be damaging for many devices. Therefore, files being played via the ITunes are protected and not allowed to be compatible with any other player.
There are many benefits, when you have DRM protection or security in the applications for music and videos. One of the benefits is that DRM security acts as a filter for all the files, which are being downloaded and played on such advanced platforms. You don¡¯t need to worry about your applications facing troubles, whilst playing music. The harmful files will be automatically blocked by your active DRM security for ITunes or any other application for music and multimedia purposes. Thus, applications such as ITunes will play only authorized and safe content that is entirely benign.
However, this DRM protection may serve as a barrier for playing any other ^} music and video files on the Apple players as well as other player systems. One of the ways to remove drm itunes can be explained as follows. First, you have to select the files that you have purchased from the ITunes store. When this is done, you need to burn them into a CD or a CD-WR. Then, you need to copy back the burned files into a new ITunes playlist. Once this is done, you need to save the new playlist and delete the original list. Thus, your DRM protection will be removed permanently.
Some other methods involve converting the DRM protected tracks and files into universally compatible formats. One of them is to download or purchase a new DRM Removal Software. This application is compatible with most of the new and advanced Windows operating systems. All you need to do is to import a list of DRM protected songs and videos. You can select a suitably compatible and universally applicable format for these files. Once this is done, you need to click on Convert. With such easy steps, these files will lose their DRM protection and they can be played on any ordinary platform.
Finally, there is another way toremove drm from itunes . This is to use the QTFairUse Freeware program. This program acts as well as any other application for removing the DRM protection systematically. With some easy and handy keyboard clicks, you can get many of your protected files converted into MP4 and mE4 formats. You need to type in Y and Enter to get all your files converted to new formats. These stored files can be played on many players and systems for multimedia.
The simple way to use Aimersoft drm media converter that can help you remove itunes drm ,then after removing drm ,you can enjoy the files on various portable players such as iphone, ipad,ipod,etc when you remove drm itunes movies.
Video Game Consoles & Games Logo
when i turn on my zune it just continues to restart. it showed a code 5 error message. What is it and can i fix it
you receive the message when A Windows Digital Rights Management component is corrupt.
Things to try
  1. Reset the DRM system on the computer. Warning This procedure affects all media files on the computer that use Windows Media DRM technology. The effect of this procedure is not limited to media files that you obtained from the Zune Marketplace. If you follow this procedure, content licenses for all protected media files on the hard disk are deleted. Other providers, such as, Napster, MSN Music, and Wal-Mart, use different mechanisms for restoring licenses. If you have content from other providers, examine the appropriate license restoration policies before you continue.To reset the DRM system on the computer, follow these steps:
    1. Verify that the Show hidden files and folders option is turned on. To do this, follow these steps:
      Windows 7 or Windows Vista
      1. Start Windows Explorer. To do this, click Start, type userinit.exe in the Start Search box, and then press ENTER.
      2. Click Organize, and then click Folder and Search Options.
      3. Click the View tab.
      4. Click Advanced Settings.
      5. Under Hidden files and folders, click Show hidden files and folders, click to clear the Hide Protected Operating System files (recommended) check box, and then click OK.
      Windows XP
      1. Start Windows Explorer. To do this, click Start, click Run, type userinit.exe, and then click OK.
      2. Click Tools, and then click Folder Options.
    2. Locate the DRM folder on the computer. Typically, the DRM folder is located in the following location. Note In these paths, drive represents the drive on which Windows is installed.Windows 7 or Windows Vista
      • Windows 7 or Windows Vista x86-based versions
        drive:\ProgramData\Microsoft\Windows\DRM
      • Windows 7 or Windows Vista x64-based versions
      Windows XP
      • drive:\Documents and Settings\All Users\DRM
      Note If you have upgraded from Windows 98 or from Window ME to Windows XP, the DRM folders may be located in C:\Windows\DRM.DRM folders can be located in various locations in different versions of Windows. You can also locate the DRM data path in the registry. DRM data is located in the following section of the registry:
      • x86-based versions of Windows XP, Windows Vista, or Windows 7: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      • x64-based versions of Windows 7 or Windows Vista: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      To locate the DRM path in the registry, follow these steps:
      1. Start Registry Editor.
          Windows XP
          • Click Start, click Run, type Regedit, and then click OK.
          1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, type run in the Start Search box, and then click Run under Programs.
          2. Type regedit.exe in the Open box, and then click OK.
            Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
      2. Look for the applicable folder based on the version of Windows that you are using.
    3. Rename the DRM folder to DRMbackup.
      1. Right-click the DRM folder, and then click Rename.
      2. Type DRMbackup, and then press ENTER.
      3. Close Windows Explorer.
        If you receive an “Access denied” error message when you try to rename your DRM folder, start the computer in safe mode and log in as the computer administrator. To do this, follow these steps:
        1. Restart the computer and start pressing the F8 key on your keyboard. On a computer that is configured to start multiple operating systems, press the F8 key when the Boot menu appears.
        2. Select the safe mode option when the Windows Advanced Options menu appears, and then press ENTER.
          The Boot menu appears again and the words "Safe Mode" appears in blue at the bottom of the screen.
    4. Reset the DRM security component. To do this, visit the following Microsoft Web site, and then follow the steps to upgrade the DRM security component: http://go.microsoft.com/FWLink?LinkID=34506 (http://go.microsoft.com/FWLink?LinkID=34506)
      Note When you access this site through Internet Explorer on a Windows Vista-based computer, you may receive a "user account control" popup message that requires that you enter the administrator password to continue. Note If you are running a 64-bit version of Windows 7 or Windows Vista x64 and the Upgrade button on the site listed earlier in this step appears dimmed, you will have to start Internet Explorer by using an account on the computer that has Administrative privileges in order to continue.
    5. Sign in to the Zune Marketplace. Then try to play a song to verify that the issue has been resolved.
    6. Restore the setting of the Hidden files and folders option. To do this, follow these steps:
Oct 31, 2009 | Audio Players & Recorders
2,311 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
