Tip & How-To about Kodak Office Equipment & Supplies
Dont Throw it away
Need your printer paper tray fixing then contact me asap,
Lugs broken off i can fix it no worries, so you dont have to send it back and wait weeks from the manufacture
How to get printer to grab paper?
Your printer has a mechanical problem. and you should take it yo repair. Probably som internal part has broken and should be replaced.
Normally this kind of faults can't be repaired by user because the so called "reparation kit" is only available for authorized repair shops.
Jun 23, 2015 | Brother MFC-J265W Multifunction Printer...
When loading paper tray on lexmark optra t614, one sheet of paper comes out of the front. Looks like feed rollers are sitting too low? I dont know what part to buy that will fix it. I guess I could use a pdf of parts and numbers.
if the pick wheels are just hanging down you need a bell crank for the auto-compensator this part is 56p1228 turn the printer onto its back this plastic piece is known to break. look to the right its located on the end of the long shaft comming fron the auto compensator and if its broken there should be a spring either in the tray of still hanging from the mount
Oct 28, 2009 | Lexmark Optra T614 Laser Printer
paper tray is in the printer,but the printer says missing tray 1
There are two possible solutions: The first is that the lugs on the side of the paper tray are broken, and the printer cannot "see" a paper tray. In this case you need a new paper tray. The other possibility is that the tray and paper size sensor inside the printer is faulty. Often just pushing the contacts can free them, and sometimes the metal prongs that sense the lugs on the side of the paper tray get unseated. Just use your finger to reseat them correctly. If that doesn't work, the sensor board is likely to have failed, and will need replacing
Jun 11, 2009 | IBM Infoprint 1120 Laser Printer
SCX-4200 Paper jam
dont worry clean the black roller gently with wet cloth
Apr 17, 2008 | Samsung SCX 4200 All-In-One Laser Printer
tray broken
Hi lisa,
Try to re-install the printer drivers this should reset your printer back If that dont work you may have to buy a new one.
Jan 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
3,338 people viewed this tip
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
