Tip & How-To about Microsoft Video Game Consoles & Games
General Maintenance for Xbox 360.
Just some general maintenance tips for your xbox 360.
1. Making sure to leave the box flat on the ground as when put standing up it can shake and cause damage to discs.
2. Never ever move your xbox while a disc is running inside. This will usually result in the disc being damaged.
3. Keep the xbox in a well ventilated place. Overheating can occur if your not careful.
4. Ensure the xbox is free from dust especially around the vents as again this can cause over heating.
Thanks and hope these tips are useful!
Video Game Consoles & Games Logo
When i tip my xbox 360 it makes a weird noise then scratches the disk until it is unreadable.
Moving the Xbox 360 while turned on can result in the disc spinning against hard plastic resulting in deep circular scratches. When moving the Xbox, make sure it is empty of discs and the power is off. It is recommended to have the Xbox parallel to the ground but you may also stand it up for convenience purposes.
Aug 06, 2011 | Microsoft Xbox 360 Console
My X box 360 keeps having open tray on the screen. I have put in several games but this keeps coming up....
This has happened to me before also the disk tray has lost alignment with the laser the best thing is to wiggle the disk tray around while its outside the x-box and sometimes even shaking the xbox while turned off may solve this problem. Hope this helps please leave a good rating
Feb 28, 2011 | Microsoft Xbox 360 Console
xbox360 help
Make sure that its in a well ventilated area so it can run coolly.. If you end up getting E74, or the 3 red rings you will need to call
1-800-4my--xbox
Overheating could be a sign of future breaking..
just be sure its in a well ventilated area as I said
Nov 23, 2009 | Microsoft Xbox 360 Console
my xbox 360 keeps puting scratches on my games
check to see if anything is obscuring the disc tray on opening and closing.
If there isnt check the disc make sure its smooth and flat no bumps and not bent
if there is noises like grinding when playing it may be a part inside causing this
i suggest calling xbox because i dought u want to risk doing this to other games.
please rate. thank you
Dec 17, 2008 | Microsoft Xbox 360 Console
1,007 people viewed this tip
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
