Tip & How-To about Cell Phones
How to fix a phone that dropped into water
Hi, when ever a phone drops inside the water, First you will need to remove the battery from the cell phone.If the battery is left inside the cell phone, the water will damage the cells inside the battery, why?, because there is still Power inside the cell phone that can damage the battery cell.
To service the phone,you will need to unscrew the cell phone,because has entered into the cell phone and it can damage IC chips inside the cell phone if not attended to immediately.
Use a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.(depends on the type of phones)
Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
After some minutes,assemble the phone back and fix in the battery. Make sure during the process you are charging the battery of the phone. battery might be dead or low in power..Better you can have a spare battery around
after servicing the cell phone..
I guess that's all you need.
Note: if the battery has stayed too too long on the phone and am sorry after the water splash, it might not come on after this all process, that means you will have to flash the phone because the battery might have damaged the memory of the board of the phone and will not power up the phone because the phone is too weak to power.
Flashing of the phone will restore back the phone memory.
That's solves your problem.
Cell Phones Logo
how do i get water out from under the touch screen ???
Hi, when ever a phone drops inside the water, first remove the battery cause the battery life might be damaged,and also in that process the phone is still working because the battery is still inside the phone.
You will need to service the phone for the phone to be free from water,cause if the water dries inside the phone it will damage an IC or a chip inside the phone and it might cause more damage to the phone.
After, disassembling the phone is the next step.
Get a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.
After some minutes,assemble the phone back and fix in the battery. Make sure during the processyou are charging the battery of the phone.
You can visit the below link to learn more about flashing of phones.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Hope it helped.
Feel free to pass your comment.
Thanks for using fixya.....
Jun 16, 2011 | Sony Ericsson XPERIA X10 Cell Phone
dropped it for 2 seconds in the shower...picked it up right away.....water seems to appear on in the screen....what to do ?
and
Hope it helped.
Jan 21, 2011 | Cell Phones
samsung genie GT-S3650 drop in my drink help
Water problem or drink.
Hi, when ever a phone drops inside the water or drink, first remove the battery cause the battery life might be damaged,and also in that process the phone is still working because the battery is still inside the phone.
and
Hope it helped.
Jan 18, 2011 | Cell Phones
how can i take my lg prime phone aprt so i can let it dry because i dropped it in water
you can use the below link to know how to disassemble LG phones,just type the model of the phone on the search box.
lg-phones.org/lg-optimus-7-disassembly-guide.html
After, disassembling the phone is the next step.Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
Hope it helped.
Jan 17, 2011 | Cell Phones
Drop Samsung Upstage in water
wow, himan and masir really have no idea what they are talking about. clean it properly before inserting the battery? remove the battery and get it serviced? you 2 are idiots. the upstage battery can't be removed without disasembling the entire case and then desoldering the battery from the board. i bet you 2 are probably the same people that get complaints left and right when people call dell and get an outsourced call center...
May 19, 2008 | Samsung UpStage SPH-m620 Cellular Phone
2,913 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
