Tip & How-To about Linksys Computers & Internet
How to reset a router
Routers have a reset button on the back usually next to power inlet. This is usually amenable to pressure with fine pointed object. Find a ball point pen and tip of which is ideal for the purpose. Do not reset a router unless you are sure to erase any new settings made after the purchase of router!
Press and hold reset button for 30 to 60 seconds and some times even longer is needed. This process puts router back to factory default setting which means any modification done by user are lost!
Computers & Internet Logo
how do I change a forgotten admin password
You'll have to default the router back to outta the box settings. To do that you hold the reset button in with a ball point pen or tooth pick for 6-10 sec depending on the brand. You don't say what brand. The button is normally recessed in a hole on the back next to the power jack.
You can find a list of default passwords on the internet by brand and model number. Linksys/Cisco is usually User Name <blank> and Password admin. Then once inside you'll have to reconfigure everything unless you have the config saved on a PC or Laptop.
Apr 30, 2016 | Computers & Internet
can't remember the security key
you mean the key for wifi? then the solution is to reset the router and set up a new security key! Resetting the router is simple. Just press and hold the reset button for 30 to 60 seconds. The reset button located on the back of the router. Use a pointed object like ball point of a pen!
Sep 16, 2011 | Linksys WRT120N Router
trying to figure out how to set up the wireless featurei belive its been shut off
find the reset button on the back (usually) press it with a small sharp object (ball point pen) the router will now be reset to default settings, which with linksys is usually wireless "on".
Mar 17, 2011 | Linksys Computers & Internet
how do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Mar 08, 2011 | Magellan RoadMate 1220 GPS Receiver
router does not recognize my internet connection. what can i do to fix it?
Reboot your "modem" first, if it has a battery backup, disconnect it first. You want the "modem" to totally lose power. Plug it back in and let it sync up before proceeding to next step.
Next: On the back of your "router" you will see a small hole with a button inside of it, press and hold it down for 10 seconds. I usually use the tip of a fine ball point pen or end of a paperclip to do this.
You will need to reconfigure your "router", things like wireless SSID, wireless security, router password and such.
Oct 13, 2009 | Linksys Wireless-G WRT54G Router
2,284 people viewed this tip
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
