Tip & How-To about Water Heaters
Emergency water supply
When a storm hits or other things go wrong we need water. We can go for two to thee weeks with no food, But at best we can only go three days with out water.Your water heater is a stores 40, 50 60 gallons of water. for a family of 4 that could last you 10 days with some left over. Its your life and family proteect them.
What you need to do. First make sure you have to good working valves on your water heater one on the hot side and one on the cold side. You need to flush out your tank every year. Then let's say a hurricane is heading right for you. All you need to do is close off both the hot and cold water valves. Have a 4 foot section of hose that you cleaned before the storm. Now you need to get water.
Hook up your hose to the drain on the heater, OPEN the relief valve to let air in. Open the drain valve get the water you need and close both valves. Clean water you can drink right away. Save your family fire,shelter,water this first things we need to live
Water Heaters Logo
my reliance 606 is electric 240v my problem sometimes have hot water two days and the other day have cold water
Water heaters typically don't repair themselves every other day.
That suggests something electrical is connecting and disconnecting.
Good news is ordinary tank-type electric water heaters are fully repairable by homeowner using generic parts from home center or hardware.
Could be one of three things: Problem is this, if water heater is working correctly at that moment, testing might not reveal source of trouble. Best to do testing when water heater is not working. If you don't want to test, then do step 3 below and see if problem persists, and then move out from there.
1) Circuit breaker not making full contact.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
2) Loose wire/bad wire inside tank: Open covers and check for loose screws and signs of high heat and burning:
Do a full troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Malfunctioning thermostat. Replace both thermostats for $28
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 05, 2011 | RELIANCE ELECTRIC WATER HEATER
My water heater is not turning on at all.....it is three years old
There are many things that could be wrong with an oil fired hot water heater...oil burners are not something that a novice should mess with as they can be very dangerous...
Please hire a por to figure thsi out for you..
heatman101
Jan 30, 2011 | RTO Bock Water Heaters 32E 32 gal 104,000...
Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Sep 09, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
pilot goes off every two to three weeks
Check voltage at the gas valve and at the thermocoupling. If you are reading more then 24 volts at the gas valve then replace it, or less then replace it also
Feb 10, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
635 people viewed this tip
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
