Tip & How-To about LG RD-JT30 Multimedia Projector
Resetting the Lamp Timer
After replacing the lamp, you need to reset the lamp use timer. The manual is a bit cryptic on how this is done. The manual says "Fn. Up > Fn. Dn. > Vol. Dn > Vol. Up > Enter > Power" However, my remote has no "Fn" or "Vol." controls. Further study of the manual shows that "Fn. Up" = joystick up; "Fn. Dn" = joystick down; "Vol. Dn" = joystick left; "Vol. Up" = joystick right; "Enter" and "Power" are keys on the Remote, "Enter being "6 o'clock" position on the ring encircling the "joystick" I am calling the control that one would use to move the cursor on the screen the "joystick" Thus to reset the timer, key in from the remote "cursor up" "cursor down" "cursor left" "cursor right" "enter" "power"
LG RD-JT30 Multimedia Projector Logo
message on screen says lamp needs to be replaced then timer reset. Need lamp and instructions to reset timer
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
Nov 01, 2012 | JVC Lamp W/ Housing For Hd-52g786 /...
how to change lamp timer on sanyo plvz4
Hello
* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.
* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button
8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
tv image will not show , it turns off it says ... something about the lamp inside the tvneed to be replaced?
The lamp timer on your unit has reached the max hours. it needs to be reset. There should be a reset feature in the menu. You should replace the lamp. It will brighten up your picture too. It must be done soon as once the timer reaches a limit your unit will not turn on at all. Check your manual for proper lamp type and replacement proceedure.
Feb 27, 2010 | Panasonic Televison & Video
AFTER REPLACING LAMP THE LAMP LIGHT IS STILL FLASHING
Look in the manual under "resetting the lamp timer"
This must be done with most any replacement
Browse to:
http://www.retrevo.com/r/391dj496/48/Lamp+Timer+Reset#q=JVC+HD-61G787
On that page is the (lower) is the exact procedure on resetting the lamp timer. You can also down the entire manual in PDF format.
Cheers
Jan 15, 2010 | JVC HD-61G787 61" Television
A warning pops up on the screen of my Panasonic PT50LC13 That my lamp needs replacing and I need to reset the lamp timer, how do I reset the lamp timer?
After replacement of lamp, turn on TV, press and hold Volume Down button on TV front and press and hold Split/ Play button on TV remote at same time for 6 seconds.
That will reset lamp timer and confirmation display will come at TV screen.
Above info are also available in original Panasonic replacement Lamp box.
Aug 19, 2009 | Panasonic PT-50LC13 50" Rear Projection...
881 people viewed this tip
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
Lawrence Oravetz
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
