Tip & How-To about Computers & Internet
Cisco 3925 Router Password Recovery
TheCisco 3925 router is part of a family of networking equipment produced byCisco, which has been a network equipment giant for many years. Used 3925routers are available on the Internet at reasonable prices, so acquiring one isnot difficult. However, if the password is unknown or lost, reconfiguration isimpossible until the password is reset or recovered.
Cisco has built in aprocedure for rescuing lost or forgotten passwords or entering new passwords.
ThingsYou'll Need: Serial to RJ-45 cable;Terminal emulation software
Instructions
1.Connect your computer to the router with the blue serial-to-RJ-45 cable thatcame with the router.
The 9-pin D-shell end connects to your computer's serialport, while the RJ-45 end connects to the console jack on the router.
The RJ-45end resembles a slightly larger telephone jack connector.
2.Turn on your computer and establish a terminal session to the 3925. You can use any terminal emulator, and many are freely available on the Internet.
Configure the session settings as follows:9600baud8data bitsNoparity1stop nonflowering controllable router's power cable into an electrical outlet, and as the 3925 boots, you should see the Cisco boot messages.
If you don't see any output on your computer's terminal session, check your settings on the session and restart itif necessary.
Press "Break" within 30 seconds of powering on the router to enter rommon (rom monitor) mode.
3.Type "confreg 0x2142" and press "Enter" at the "rommon1>" prompt. This will cause the router to boot from its internal flashmemory without loading the configuration into memory.
At the following"rommon 2>" prompt, type "reset" and press"Enter."
This will cause the router to reload and ignore thepreviously saved configuration file.
4.Respond "no" and press "Enter" when prompted for responsesto enter the initial dialog or basic management setup.
Type "enable"and press "Enter" at the following "Router>" prompt.This will put you into enable mode and display the "Router#" prompts.Copy the non-volatile memory into memory with the "copy start up-config running-config" command, followed by the "Enter" key. Type"sho run" at the prompt and press "Enter" to display the current configuration, including the passwords, some of which may be encrypted.
5.Type "config t" at the prompt and press "Enter." At the"Router(config)#" prompt, type "enable secret "-- where "pswd" is the password -- and press "Enter." Atthis point, your enable password is reset. Press "Ctrl" +"z" to return to the "Router#" prompt.
6.Type "config t" at the "Router#" prompts and presses"Enter." At the "Router(config)#" prompt, type"config-register 0x02102" and press "Enter" to reset theboot register to its normal setting. Press "Ctrl" + "z" toleave configuration mode. Type "copy running-config startup-config"and press "Enter" to save your changes. Reboot the router and youshould be able to login with your password.
Computers & Internet Logo
what is different router and modem
Hello there,
In networking terms, a router is a Data Communication Equipment (DCE) device which is simply your gateway to the internet and is mostly used by Internet Service Providers (ISPs). A router is an intermediary device which also performs packet routing. It determines the proper path for data to travel between different networks, and forwards data packets to the next device along this path. Essentially, they connect networks together.
A modem, on the other hand, a Modem is a "MOdulator/DEModulator". It modulates an analog carrier signal to encode digital information. In layman terms, subscribers use it to gain internet access in their respective homes and offices. It is also called a Data Termination Equipment (DTE) device which is on the subscriber end of the network.
Hope this helps...
Jan 19, 2011 | Computers & Internet
dell dimension 3000 won't see wireless network
Hi, I've jst been looking on the web at the Mimo routers, you may find this article interesting, it may help even though its a couple of years old?
http://www.behardware.com/articles/614-2/wi-fi-mimo.html
Pay attention to part about 802.11n compatibility?
Perhaps try changing the IEEE standard on the router to 802.11g in the set up pages, as it may be set at 802.11n, which your older wireless card will not see.
As to the acquiring ip address message, try using a static ip address, here's a good guide:-
http://portforward.com/networking/static-xp.htm
Maybe this will help?
Jan 27, 2009 | Dell Dimension 3000 PC Desktop
2,314 people viewed this tip
David Payne
David Payne
