Home | All Products | (DVP5140) DVD Player | Tips
Common mechanical problems with dvd players not playing or reading discs.
BobbyR1234
By Guru BobbyR1234
Rank: Guru
Rating: 88%, 415 votes
posted on Sep 07, 2008
Helpful
The most common mechanical problems that can prevent a dvd player from playing or reading the discs are the following:
1. The spindle motor not functioning properly (this is by far the most common, if the spindle motor is not spinning the discs then the optical lens can not read them). For the most part it is an cheap part to replace averaging around 25-25 dollars if you can replace it yourself. If you do not know how and have to take it to a repair shop expect to pay 50-75 dollars in labor. The key is to listen closely when you insert the disk into the player, you should be able to hear it spin up. If you hear nothing then that is most likely the problem.
2. The cd tray could be out of alignment. This is another easy and cheap fix if you have the proper tools. This could happen if you drop or pull and push on the cd tray.
3. The small gears are plastic and often break, this will cause the players other parts not to move and function properly also. They are hard to get to, but inexpensive to replace from the manufacturer. A visual inspection is usually required to determine if the small teeth have been broken, which requires for the most part taking out the carriage assembly.
4. The small belt drives either break or come off. Again, this will cause the other mechanical parts not to function. They are a pain to put back on also. There are usually 2-3 of them inside your player.
5. The Optical reader has malfunctioned. This is the most expensive thing to replace, so you might as well buy another player unless you can find a great deal on one someplace. You can check to see if the laser is firing with a visual inspection (DO NOT LOOK DIRECTLY INTO THE LASER) put in a disc with the case off and you should see the glow of the laser hitting the disc.
6. The tray also has a drive motor which can fail and cause the cd tray not to open and it also has a track that it rides on. Check these two components if you are having problems with your cd tray.
Was this helpful?
Yes
No
16 people thought this was helpful
Comment #1
posted on Oct 24, 2008
Aslam_Indian
By Apprentice Aslam_Indian
Rank: Apprentice
Rating: 0%, 0 votes
I have got similar problem as "andip"..Any solution?
Comment #2
posted on Oct 06, 2008
andip
By Apprentice andip
Rank: Apprentice
Rating: 0%, 0 votes
I have a Philips portable DVD player (model PET702/37) and my child dropped it and now it is not playing discs. When I put a disc in I can hear it spin, then it begins to click (like something isn't connecting or catching) and then it tells me 'no disc'. Do you have any idea what this might be and if it can be fixed and is worth it to have it done. It was not an expensive player (90$) but I hate it when something doesn't work and if it can be repaired I would like to do so. We do use it frequently.
Thanks for your time and attention.
Comment #3
posted on Sep 24, 2008
Sixxtyone
By Apprentice Sixxtyone
Rank: Apprentice
Rating: 0%, 0 votes
Well, My JVC DR MV1s is reading and records my DVD-R but it stop reading and writing DVD-RAM and RW. What do you think the problem is there, Do you think I need a cleaner?
Can you Help with these DVD Players problems?
Philips (DVP5140) DVD Player
I just watched a movie and it was fine, I put in another...
New battery for technosonic portable dvd player DVP 2111
Hy there. I have a Power Problem with Philips DVP5990/37:...
have a dvp3962 is asking for password,is ther a universal...
locked my dvd player and i dont know the password to it
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
