Tip & How-To about Google Android
How do I Capture Screen Photo on my Android
Get a screenshot on an Android device requires some effort, but it is workable once you have the proper tools. A screen capture method requires connectivity with the PC, the other requires root access. Instructions for both methods are shown below.
With root privileges
1. Gaining root access on your mobile device Android. This process varies according to device, and may be prohibited by certain carriers. Finding the root process for the device and make sure that no warranty or cancel service contracts.
2. The launch of the Android market towels and install an app called Screenshot.
3. Choose a preference to take a screenshot. Screenshot of the application allows screens to be set on a programmed delay, keeping the camera button or a button to activate the device to take a screenshot.
4. Take the screenshot. The image is stored on the SD card, and can be transferred to PC via USB, method of transferring e-mail or other file.
Without Root privileges
1. Download the Android Software Developer Kit on your computer if you cannot access the root of your device to get. Make sure you have the correct version to install the SDK is available for Windows, Mac and Linux.
2. Connect your Android device to the computer via USB.
3. Prepare the drive by setting the screen that you want to be recorded.
4. Open the Debug Monitor Server Dalvik selecting the DDMS tool under the tools directory of the SDK folder. Mac and Linux users should run the tool from the terminal.
5. Choose your device from the list. Then click the "Device" menu and select the option to "screen capture". A window opens the current state of the device screen. Select "Save". Now you have a screenshot of your device have Android.
Google Android Logo
Can you do a screenshot on the Trio Stealth G2 9.7 Tablet?
This should work on any Android 4.0 and newer tablet.
To take a screenshot on your device, press the Volume Down and Power keys at the same time.
The screen will flash, you'll hear a sound, and you'll see a framed image appear and fade into the notification bar. The "Saving screenshot" notification will appear.
May 10, 2015 | Mach Speed Trio Stealth G2 Tablet -...
screenshot on lenovo laptop 400
Can you find the prt scrn button?
Jan 24, 2015 | Lenovo Computers & Internet
how do i take a screen shot on a motorola droid 3
The Motorola DROID 3 runs on Android and as of now, no applications are available that allow for on-device screenshots. This guide will provide you with the software you need and show you how to get stunning screen captures from your device.
Two separate pieces of software are required and must be installed on your PC:
  1. The Android software development kit (SDK)
  2. The Java SE software development kit (SDK)
Once your downloads are complete a few steps are required to get things ready.
On your computer:
  1. Extract the Google Android SDK to a folder on your desktop
  2. Install the the Java SE SDK
On the Motorola DROID 3:
  1. Press the Home icon, press Menu and then tap Settings
  2. Tap on Applications
  3. Tap on Development
  4. Check the box for USB debugging
Now you are ready to get started.
  1. Plug your Motorola DROID 3 into your computer via USB and Windows will attempt to install all of the appropriate drivers; one of the drivers will not be found and thus you must proceed to Device Manager in your Control Panel and find the Motorola DROID 3 (there will be a yellow icon next to it)
  2. Right-click on the Motorola DROID 3 entry and select properties; instruct Windows to update/install the driver for this device and when asked, simply browse to the usb_driver folder inside of the Android software development kit folder that you extracted to your desktop earlier -- the device is recognized and the driver is installed
  3. Browse to the Android SDK folder that you extracted to your desktop and run the SDK Setup.exe to start the program
  4. Once the application has launched you will be presented with a window as shown in figure 2 above
  5. Click on the Refresh button so that the application can update its list of operating system SDKs available from Google
  6. Check off the section next to the URL that is shown in the application; you are now presented with a list of Android SDKs and Google APIs you wish to install
  7. It is recommended that you select select all available packages for maximum compatibility
  8. Once the files have been downloaded simply close the application
  9. Browse to the Tools folder inside the Android SDK folder you extracted to your desktop
  10. Double click on DDMS.BAT to execute the Dalvik Debug Monitor
  11. The application will launch with a DOS command window and eventually a Windows based application -- your phone will be listed on the left hand side, and you should click on it to make sure it is selected
  12. Click on the Device menu and select Screen Capture or use the CTRL-S key combo
  13. The capture now appears on your screen, but there is one final undocumented step
  14. We recommend that you click on the Copy button and paste the screenshot into your image editor of choice (Microsoft Paint, Adobe Photoshop, etc) -- the reason for this is that there is a known bug that does not carry over the colors of the actual screenshot inside the capture utility
Voila! You now have a stunning screenshot from the display on your Motorola DROID 3. Repeat steps 12-14 to generate more screenshots.
May 02, 2014 | Motorola Cell Phones
how to screenshot on an android tablet
If you have a 4.0 or Later operating system, Press and Hold the volume and power button down together.
Jan 26, 2013 | Tablets & eReaders
769 people viewed this tip
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
