Tip & How-To about Google Android
How to Install ADW Launcher on an Android Phone
ADW Launcher is an Opensource home/phone desktop replacement application. Meanwhile, the EX Launch ADW is highly customizable home replacement applications that require you to buy it for use. It also set your desktop android. It is an Android application that normally runs when you press the HOME button phone android. It is usually what people know as the "android desktop".
To download the ADW Launcher go to Android Market, try these steps:
1. Android Market to open in your phone and go to "Search".
2. Type "ADWLauncher EX" in the search field and "Search" from the press.
3. Once you have the "EX ADWLauncher" game, choose "Install" and follow the instructions.
EX ADW.Launcher ADWLauncher is based on core opensource with a series of improvements and new features, as follows -
1. 5 different styles tray app / behavior
2. Several transitions desktop, new animations while browsing your screen. Try them all.
3. New icons settings / look and feel: Tweak desktop icons; change the size funds, to add color, change font, color, etc.
4. Presets new speed so fast the entire desktop configuration by one click.
5. Editable desktop application icons, shortcuts and folders.
Google Android Logo
How do I fix my virginmobile lg optimusv, it reads The application launcher (process com, android. launcher) has stopped unexpectedly. Please try again.
Hello there,
It looks like your launcher is giving you some trouble. You can download another launcher application (that looks better too) that might fix the problem. Try this great free launcher! https://market.android.com/details?id=org.adw.launcher
I hope this helps. Thumbs up always welcome :)
May 03, 2011 | LG Computers & Internet
No anti virus and themes support my s5620 monte.please tell me the answer how i get it.
Cellular device viruses are very rare. Should you find an 'anti-virus' in a marketplace, I would simply avoid them. They are not necessary and many of them will populate with false alarms requesting you spend money to protect your device.
As for themes, your phone is equipped with Samsung's TouchWiz user interface. You can move your icons and applications around, and you may change your background, but other than that your customization options are limited.
You may try and disable TouchWiz for a different look by going to Settings, then Applications, select the Running Applications option and find TWLauncher and force close it. This is supposed to send the phone back to the stock Android launcher; On some devices TouchWiz will restart immediately with no visible effect. Stopping this process will not cause damage to your phone, nor should it cause a malfunction of any sort.
You can also check the marketplace for Launchers, such as ADW Launcher, which is much more customizable than TouchWiz.
Apr 12, 2011 | Samsung S5620 Cell Phone
I can't find a theme nowhere that I can download to my phone. I got a HTC wildfire. Where can I get one at for free.
generally themes are for home screen replacement launchers. there are a few and they can be awesome. please try some of my favorites listed from best to least preferred. then download themes from there. all of this can be accessed from the market.
1) go launcher 2) zeam 3) adw launcher 4) launcher pro after you pick a launcher search for themes on the market. adw and launcher pro will have the most themes available have fun. dont forget to poke around in the preferences of your new home launcher to set it up to your liking there are tonns of settings that can make your new launcher a real help navigating your phone. goodluck btw i wish i had your phone lol mine is a little slow for me welcome to android!!
Mar 19, 2011 | HTC Wildfire Cell Phone
I want to set a theme for my lg optimus and I dont know how to can you please help me
The easiest way to change the theme or look of the LG Optimus (or any Android phone for that matter) is to download a new launcher. The Launcher is like the desktop for Android, where you can place widgets and app icons. There are different Launcher's available to download from the Android Market, and some of them can be themed and dramatically change the look of your phone. There are multiple good ones that can be themed. Just go to the Android Market, search for ADW, OpenHome, GO Launcher EX, just to name a few that can be themed.
Once you install the new Launcher, when you hit "home" it will bring up options to choose which Launcher you want to use. Don't select "use as default" until you're sure you want to settle with one of them. (*if you do select use as default, and then want to change again, see the note at the end of this)
If you go back to the Android market, and search for ADW themes, OpenHome themes, etc., you should see quite a long list of various themes for each launcher. Install one you want to try, then hit home. You'll need to apply the theme in the Launcher's settings, which is normally accessed by (from the home screen) hitting the menu button, and then "preferences" or "adw settings" (if you're using ADW). From there, depending on the Launcher you're using, find the section that has to do with "Themes" or "UI". From there, you should be able to select and apply the theme you just downloaded and installed. It can't hurt to download a few if you want to test a few.
Changing Launchers is a great way to change the look and feel of you're phone, as a lot of them run much smoother than the Launcher that comes default on the phone.
*If you set a Launcher as default, but want to change it... the easiest option is to download "Home Switcher for Froyo" from the Android Market, and use that to change between Launchers. The longer was is to go into Settings -> Applications -> Manage Applications, find the Launcher you're using, click on it, and select "clear defaults". Then when you hit the "home" button, it should bring up your options again.
Mar 05, 2011 | LG Cell Phones
how to install themes to samsung galaxy 551 phone
you can download
1.GO launcher
2.ADW launcher
3.Launcher Pro
4.Regina 3D launcher
5.Panda Launcher
6.Honeycomb Launcher
7.Home Launcher
from Market and install it
and within any launcher you will get many theme
and also you can customise them
Try it
Feb 19, 2011 | Computers & Internet
279 people viewed this tip
Top Google Computers & Internet Experts
Robet
Robet
Sunil Pratap Singh
Sunil Pratap Singh
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
