Tip & How-To about Refrigerators
What is wrong when your freezer is frosted and the refrig, is warm
That is going to be a problem with one of the components in the automatic defrost system. It is supposed to automatically defrost. Turning it off overnight to melt it will defiently help. If you are mechinacally inclined here is what to check to see why it isn't defrosting;
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven,or in some cases it is going to be a spiraled wires inside of a glass tube. To check it,use a multimeter set to the lowest ohms of resistiance setting and follow and find the wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST CONTROL...it is hard to check for a semi unskilled person and if the heater or defrost t-stat check good its going to be the problem. It will NOT be in the freezer it could be on back wall or inside the control panel in the refrigerator section.
Good luck,
Gene
While these pictures are for a different brand ALL refrigerators are similar and may look some what different than your but will be similar enough
Refrigerators Logo
I have a GE Side by side Fridge with model #TFX27PFSM WW and the coils were completely frozen. I used the hair dryer on them and thawed them out. As soon as I plugged the fridge back in, they immediately started to ice up again. Any ideas?
Its normal for the evaperator coil in the freezer to have frost on it that is a sign of a heallthy good working compressor...WHEN IT BUILDS UP SO THICK their is no gaps in the coil and its just one huge iceblock that is where the problem lays. Thier is a automatic defrost system that is supposed to periodically come on and melt the frost and a component from it has failed allowing the frost to build up so thick it has restricted airflow through it.
The most probable problem is going to be a bad defrost heater it by far is the leading problem when a GE brand ref.doesnt automatically defrost.
This tip i wrote explains how to check and see why its not automatically defrosting
http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Sep 24, 2011 | Refrigerators
After defrosting my Vestfrost Fridge/Freezer it takes only a couple of weeks to need to be defrosted again. What could be the problem?
That is going to be a problem with one of the components in the automatic defrost system. It is supposed to automatically defrost. Turning it off overnight to melt it will defiently help. If you are mechinacally inclined here is what to check.
Good luck,
Gene
Aug 15, 2011 | Refrigerators
freezer doesn't seem to defrost. water entery tube to icemaker appears to be froze shut do I need a new heater element? refrig model is GR2SHK/GR2SHM
Good luck,
Gene
freezer is iceing up and will not freeze. the fridg will not get cold
Good luck,
Gene
Aug 14, 2011 | Roper RT14DKX Top Freezer Refrigerator
freeze's up
Good luck,
Gene
Aug 14, 2011 | Magic Chef CTB1722 Top Freezer...
4,871 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
