Tip & How-To about Dryers
How to connect yournew dryer cord
It seems to get confusing where the wires go in the back where the cord connects to on your brand new,or previously dryer that you have brought to a home thats new to you
4 wires goes as such with the red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago.
3 WIRE CORD
The 3 wire cord goes just like this see the 2 wires on the outsides of the cord going to the black/red wires .The wire in the middle of the cord goes on the middle terminal on the cord block
Dryers Logo
i have a 3wire prong dryer and the outlet os for a 4 prong dryer, l have the 4 prong cord but don't know how to connect it can you help?
4 wires goes as such with oldtech2332.jpgthe red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago
GENE
Oct 16, 2011 | Dryers
WHIRLPOOL LER5636EQ3 HOW TO CHANGE THE DRYER CORD FROM 3 PRONG TO 4 PRONG?
4 wires goes as such with oldtech2332.jpgthe red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago.
GENE
Oct 12, 2011 | Dryers
need to know which color wire on a new plug goes to which screw on the back
This is how to connect both 3&4 wire cords;
3 WIRE CORD
Aug 27, 2011 | Whirlpool LER4634J Electric Dryer
just pick-up 1990 dryer model no DEDM-L-6 Need help connecting pig-tail
3 WIRE CORD
Aug 24, 2011 | Dryers
need help hooking up a 3 prong dryer outlet to a 4 prong dryer outlet
You will not be able to connect a 3 wire cord you need to install a 4 wire cord and this is how it goes on
Aug 21, 2011 | Maytag Neptune MDE5500AY Electric Dryer
3,182 people viewed this tip
Top Dryers Experts
Dan Webster
Dan Webster
