Tip & How-To about Black & Decker B2300 Bread Machine
Removing The Bottom From a Black & Decker B2300 Bread Machine
Things you will need
  1. A large clear table with lots of room to work.
  2. At least 4 small dishes to keep screws organized.
  3. A few screwdrivers - 1 or 2 Phillips head, 1 or 2 straight (slotted) with long shanks are best.
  4. A straight screwdriver to be modified
  5. Utility knife or Xacto knfe
How-To open up the breadmaker
  1. Modify a straight screwdriver by taking a dremel tool with a 1/32" or 1/64" thick cut-off wheel and grind a notch in the centre of the blade as pictured below.The depth of the notch is best around 1/16" deep because there are other screws in the machine that will need this screwdriver. However for our purposes here we only need it for 2 screws
  2. Proceed to remove the screws from the bottom of the machine. There are 4 Phillips/Straight screws (can use either type) and 2 of the special screws and set to the side in a dish. The screw locations are shown below: 1=Normal Screws -- 2=Special ScrewsThe special screws look like:
  3. Turn the machine over and disassemble the lid by opening up the lid and removing the 5 screws shown below and set aside in a dish*Note be careful when removing the metal plate, the window is made of glass and can easily fall out and break, remove carefully. Also the plastic vent is just sitting in its opening and can fall out.
  4. Once you have removed the metal plate, remove the 2 screws holding the lid to the hinges and slide the lid off the hinges, put screws with the others from the lid as they are the same. Screws shown below
  5. Remove the controls and display. There are 3 screws as shown below, they are covered by little white plugs which are most easily removed with the point of a utility or Xacto knife, put the screws and plugs in a dish.There are also 4 clips holding the panel in place, 2 pop off easily, the last two are near the display and can be awkward
  6. Now remove the 8 screws from the bottom of the "oven" walls, locations shown below and put in a dish.
  7. There are 8 clips inside the machine that hold the top to the bottom, with any luck they won't really be holding well and you can lift the top off. Start by pulling the left side up, letting the clips pop open. While lifting the top, carefully feed the control panel through the opening below it and finish taking the cover off. If the top doesn't come off easily, you may have to remove the "oven" walls by carefully prying up the top lip. If you get stuck the seal around the outside of it can be removed as well with the use of a small screwdriver or a utility knife.
There you now have the cover off and you can have fun working on the innards of the machine.
One problem area I discovered is the main drive belt. You may want to check that if the machine suddenly stops running and you think the motor is fried. The problem is the pulley on the motor shaft can slide up towards the motor causing the belt to slide off.
Reassembly
Reassembly is simply the reverse of of the above procedure.
Conclusion
I hope this guide has helped and good luck repairing your machine.
You can also find this guide at my site at ianchristie dot info
Direct link to the original article Removing The Bottom From a Black & Decker B2300 Bread Machine
Black & Decker B2300 Bread Machine Logo
We have a large three-generation family, and during the holidays, I would really like to buy a smaller table for the kids to sit at that will be both fun for them and relaxing for us. Can anyone recommend a good kitchen/dining room table for young kids?
If your looking for a small dinning room table for your grand kids that doesn't take up a lot of space you can check out Four Chairs Furniture. They are the best Utah furniture store and the best thing about them is that you can live anywhere and they can ship it to you. I was limited in space for my apartment and I found a great sofa and table from them. Check them out I know they will be a good fit for you.
Aug 09, 2012 | Furniture
Should I get end tables with drawers?
Furniture with storage drawers are also beneficial, specially when you have a small size room. A number of furniture stores like the Furniture Zone & Sleep Shop offer various designs, depending on the number of drawers you want.
May 29, 2012 | Furniture
What do I need to consider when picking out a drafting table for my workshop?
There are a few things to consider when picking out whichtype of drafting table to get:1. Determine if you need the table for long termor short term use2. Figure out the largestpossible paper you could use3. Calculate much room do youhave to store the drafting table4. Decide whether you want tosit or stand at your drafting table
my microwave keypad doest not work apparently. It says "service may needed". How can solve this error.
HELLO.
The solution to your microwave problem is explained below.
Things You will Need
* Phillips screwdriver
* Foil
* Large ziplock baggie
* Tape
* 1 Unscrew the 2 screws in the top vent grill and remove it.
* 2 Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
* 3 Put a sheet of foil into the large ziplock bag and seal it up.
* 4 Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
* 5 Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
Thanks.
Sep 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
my GE microwave (model# JNM1541DN1BB) is giving me a message; service may be needed keypad shortage. Question 1 how can I fix it myself? Question 2 why did my microwave go out and how can I keep it from happening again? Microwave is 3 years old but used very much.
HELLO.
The GE problem is with the magnetron being to close to the computer. If your microwave runs for a few seconds to minutes then resets with funny characters on the screen, you can follow these simple instructions to fix it.
needed things.
* Foil
* Tape
the way to keep it from happening again is to use the microwave with more caution.
Willing to help to help on other problems.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
2,966 people viewed this tip
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
