Tip & How-To about Maxell Flat Speakers With Subwoofer and Remote Computer Speakers
Wiring For Volume and Power Switch
I ripped the cord off the external thing-a-ma-bob for the volume and power switch on the Maxell Flat Speakers with Subwoofer unit, but managed to figure out which color wires attach to each numbered contact on the small circuit board inside the unit. The board has labeled contacts from 1 through 9, and following is the map for each color wire:
1 = Black (large wire, ground)  2 = Red 3 = Brown 4 = Orange 5 = Yellow 6 = Green 7 = Blue 8 = White 9 = Black (small wire)
I resoldered each wire back to the little board and it works like new. Much better than throwing them out and getting new ones, because these speakers have a decent sound and take up very little room.
I hope this helps anyone who runs into the same situation, because I was unable to find this information anywhere else and had to figure it out by trial and error.
Maxell Flat Speakers With Subwoofer and Remote Computer Speakers Logo
subwoofer not working
The subwoofer is dependent on a sound amp powered by an external source whereby the speakers are powered by the line output from the sound source (like a computer speaker out jack). Powered Subwoofers controlled by a power amplifier require a power source such as an AC/DC source plugged into the house power. If the device is defective or a mismatch, the subwoofer will not function. Try a new power transformer and see if that fixes the problem. Other than that, if the power transformer is good, then the woofer could be defective.
Jan 13, 2014 | MA Audio MA5137 700 Watt 5.1 Home Theater...
I need specifications about the power supply for for the Maxell FPS-1 2 speakers ...
Input Voltage: 110 V AC
Power Source: Power Supply
Frequency Response: 70 Hz to 18 kHz
Mar 04, 2011 | Maxell Flat Speakers With Subwoofer and...
I have velodyne hgs15bg powered sub.. After a prolonged hard run, it developed a rattle at mid to higher volumes. what went wrong ??
You possibly ripped the woofer cone or welded the voice coil - something mechanical. There's only one thing in there that moves on purpose.
Mar 03, 2011 | Velodyne HGS-15 Subwoofer
Blown Subwoofer
if you don't wanna get rid of it bust out your spec sheet then go here and build accordingly then rip off the old dust cap and put it back on
http://www.fixmyspeaker.com/Products.php
Mar 24, 2010 | MA Audio HK15X2 Car Subwoofer
HS 500 noise from subwoofer
Well as I see from the owner manual for this device the sub is active one and my opinion is that electric is your problem.The power of the sub and main unit must be on the same phase otherwise you'll hear brrrrr or frequency of your main unit power supply on the sub.Thats why sound changes when you open or close the door.Take one power distribution cord (get power for bought devices from the same place) and connect main unit and the sub on it and then try.I hope that this will help you
Mar 04, 2008 | Audio Players & Recorders
533 people viewed this tip
Top Maxell Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Andrew Taylor
Andrew Taylor
Are you a Maxell Audio Player and Recorder Expert? Answer questions, earn points and help others
