Tip & How-To about Garden
Trimmer/Weed Eater/Leaf Blower/ Edger/Tiller Has No Power
The first thing you should check if your machine has no power is the muffler.
If you have had the machine for a few years, or you run the fuel mixture rich, the muffle can become blocked with carbon deposits. In the muffler there is often a small screen called a Spark Arrestor. You must take it off and clean it with a stiff wire brush. Reassemble and try starting. If the power comes back to your machine, then you are done.
If this doesn't solve your problem then you must go to the next step:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
Continue to follow the next step until your machine works. It's usually a process of elimination.
Good Luck!
Jim
Key Words: Trimmer, Weed Eater, Leaf Blower, Edger, No Power, Weak, & Muffler
Garden Logo
435 will start but only will run for a few seconds. I changed plug, cleaned air filter, and replaced the fuel filter, but it still will only run for a few seconds. I have used this saw for two years and only started doing this this morning. I have always used 100% gasoline in this saw.
Check your muffler it may need cleaning, or if it has a spark arrester on the muffler that will plug with carbon and do exactly what you describe. If that checks out and you have good compression, check your fuel supply line to the carburetor for cracks or fitting loose. If not that remove carburetor disassemble and clean, replace seals with new ones and try starting. Your problem should be fixed. If not you need a new carburetor.
Jul 31, 2013 | Sewing Machines
Engine was running fine and all of a sudden it started running slower until it died. It sounds like it is starving for fuel. Replaced the in line in-tank fuel filter with no effect. After it dies I will wait about 30 seconds, it cranks again but run terrible and dies within 15 seconds. Check carb for trash finding none. I can empty the tank and when it is about run out of fuel it runs great fo a few seconds.
Check your fuel cap....try running your machine with the cap loose or off...you may have a clogged fuel tank vent... also check all the fuel lines to the carburetor to be sure none of them have degraded or have air leaks....also check your muffler to be sure it is not clogged ...hope this helps...;-D
Aug 10, 2010 | Tanaka Commercial Grade Gas Powered Hedge...
weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
Aug 17, 2009 | Honda 6370C - Parallel Power Kit For ...
948 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
