Tip & How-To about Lands Phones
Save your android's battery
1. Dim the Screen: Turn your screen's brightness down to the lowesr setting that you can tolerate. Even if you ignore the next five tips, try this one; it will extend your battery life dramatically.
2. Set screen timeouts to kick in as quickly as possible: To adjust how long your screen stays lit after receiving input, change the appropriate entry in your phone's display setting menu.
3. Turn off Bluetooth and Wi-Fi when not in use:
4. Go easy on power-hungry GPS :
5. Don't use vibrate:
Lands Phones Logo
Dell Latitude e5410...brightness changes from dim to bright on it's own. Not using battery powered. What could be going on?
You could be manually brighting it. Hitting the FN and UP arrow and Down Arrows Dim and brightens the screen, But if it does it on it own check your settings on Power Options in the control panel and on the left you will see Create a power plan sure setting are set to Balanced then click on next. You now get to pick to dim it when plugged in or on battery. I change it to "Never" becuase i like to see the screen brighter save your setting and your done.
Oct 02, 2014 | Dell LATITUDE Computers & Internet
computer screen dim
go to contol panel> power settings. Find screen brightness option for both "plugged in" and "battery". Turn the slider up all the way.
Jan 30, 2014 | HEWLETT-PACKARD ProBook 6550b XA673AW...
HP Compaq Presario R4000 (PN495AV) PC Notebook How
Yes, go to Start>Control panel>Power Options. There also should be a screen brightness key on your key board, that looks like a sun shining, with arrows pointing up & down. To use that key, hit the FN key, right next to the Ctrl key. Push & hold the FN key, while pushing the up arrow. That should increase the brightness of your display. Good luck.
Jul 06, 2011 | HP Compaq Presario R4000 Notebook
is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
how do i dim the screen brightness on a dell inspiron 1525 laptop
Look at your keyboard some of the keys have blue symbols on them, that's the second function. At the bottom left of your keyboard next to the control key there's a button that says Fn on it hold that down and then press one of the other buttons to use the second function. The brightness control is the up and down arrows. Hold Fn and press up or down to change the brightness.
Also if your laptop is set to a lower power setting the display wont be as bright. Click on the little battery symbol at the bottom right hand corner of the screen a little menu will pop up that says select a power plan if its set to power saver your screen wont be as bright.
Jan 19, 2011 | Dell Inspiron 1525 Notebook
2,494 people viewed this tip
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
