Tip & How-To about Computers & Internet
Show AM / PM Symbols in System Tray Clock in Windows 7
1. Type intl.cpl in RUN or start menu search box and press Enter. It'll open Regional and Language Options window.
2. Now click on "Addition Settings" button.
3. Go to "Time" tab and you'll see the value of "Long time" will be set to HH:mm:ss. Just add tt at last of the value, i.e. change the value to HH:mm:ss tt
4. If you want to show the time in 12 hour format (06:30 instead of 18:30), then change the value to hh:mm:ss tt
5. That's it. Click on Apply button and you'll get the AM / PM symbols back in system tray clock.
Computers & Internet Logo
Im not able to type question mark using shift
You may have the incorrect keyboard layout selected, so let's change it.
nb. the following is a step by step for Windows Vista / 7
Changing the keyboard layout:
  1. Click START and in the search box type intl.cpl and press ENTER
  2. Navigate to the Keyboard and Language tab, then find and click CHANGE KEYBOARDS
  3. Click add
  4. Click and expand the language you use / want
  5. Expand the list of keyboards, click to select the check box you want and then OK
  6. Goto options and navigate to VIEW LAYOUT and this is to compare the layout with the actual keyboard you have.
  7. Goto the DEFAULT INPUT LANGUAGE list, click the language you use and OK
  8. Hit OK again
  9. Within REGIONAL LANGUAGE OPTIONS click ok
  10. Click on the language Bar and choose the language you want.
Sep 07, 2015 | Microsoft 5000 Keyboard Wireless -...
when I type Shift + @, my new Acer computer give me " and vice versa. How may I alter this?
This is probably a different keyboard layout that you used to know.
  1. Click Start , type intl.cpl in the Start Search box, and then press ENTER.
  2. On the Keyboards and Language tab, click Change keyboards.
  3. Click Add.
  4. Expand the language that you want. For example, English (United States).
  5. Expand Keyboard list, select the United States-International check box, and then click OK.
  6. In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
  7. In the Regional and Language Options dialog box, click OK.
    Notice that the Language bar appears on the taskbar. When you position the mouse pointer over it, a ToolTip appears that describes the active keyboard layout
  8. Click the Language bar, and then click United States-International on the shortcut menu that appears.
    The United States-International keyboard layout is selected.
For more help check here
May 22, 2011 | Microsoft Windows 7 Home Premium 64BIT...
when holding down the shift keys it is typing the wrong symbols
you need to change the keyboard lay out.
Windows 7 or Windows Vista
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, type intl.cpl in the Start Search box, and then press ENTER.
  3. Click Add.
  4. Expand the language that you want. For example, expand French (Canada).
  5. Expand Keyboard list, click to select the English (UnitedS tates) check box, and then click OK.
  6. In the options, click View Layout to compare the layout with the actual keyboard.
  7. In the Default input language list, click English (United Kingdom) - English (United States), and then click OK two times.
  8. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  9. Click the Language bar, and then click English (United States)
Windows XP
  1. Click Start , type intl.cpl in the Run box, and then press ENTER.
  2. On the Languages tab, click Details.
  3. Under Installed services, click Add.
  4. In the Input language list, select the language that you want. For example, select French (Canada) .
  5. In the Keyboard layout/IME list, click English (United States), and then click OK .
  6. In the Select one of the installed input languages to use when you start your computer list, click English (United Kingdom) - English (United States), and then click OK.
  7. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  8. Click the Language bar, and then click English (United States)
Jan 08, 2011 | MSI Wind U100 Netbook
my pound sign comes up as # and my @ as "
  3. Click Add.
  5. Expand Keyboard list, click to select the English(United States) check box, and then click OK.
  7. In the Default input language list, click English(United States) - English(United States), and then click OK two times.
  9. Click the Language bar, and then click English(United States).
Windows XP
  5. In the Keyboard layout/IME list, click English(United States), and then click OK .
  6. In the Select one of the installed input languages to use when you start your computer list, click English(United States) - English(United States), and then click OK.
  8. Click the Language bar, and then click English(United States).
How to make sure that the selected layout matches the keyboard Windows 7 or Windows Vista
  1. Click Start, type osk in the Start Search box, and then press ENTER.
  2. Match the keyboard on the screen with the physical keyboard to make sure that the layout matches.
  3. To check the uppercase characters, click the shift key on the keyboard or on the screen, and match the characters printed on the keyboard.
Windows XP
  1. Click Start, type osk in the Run box, and then press ENTER.
Jan 07, 2011 | Dell Computers & Internet
317 people viewed this tip
David Payne
David Payne
