Tip & How-To about Washing Machines
Winterizing a Washing Machine
If you keep your washer in area where you need to winterize for the winter (unheated garage or unoccupied vacation home), the following steps may provide you with some helpful guidance in preparing before extreme temperatures occur and possibly leave you with damaged plumbing and/or a ruined appliance.
TOP LOADERS:
1. Turn off the main water supply to both water taps.
2. Remove the fill hoses, drain them of all water and reinstall them - leave water supply turned OFF.
3. Add 1 gallon of Recreational Vehicle (RV) antifreeze (non-toxic) to an empty wash tub.
4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub, and any water remaining in the drain pump or drain lines.
NOTE: Not all the antifreeze will drain. A small amount will remain in the drain pump and line (this is normal).
5. STOP or CANCEL the timer on the washer and UNPLUG.
6. Wipe down and dry the wash tub.
7. Clean the detergent dispenser and fabric softener dispenser and ensure they are dry.
8. Store washer, unplugged in an upright position.
FRONT LOADER:
4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub and any water remaining in the drain pump or drain lines.
5. Press PAUSE/CANCEL twice to halt the cycle and UNPLUG the appliance.
7. IMPORTANT: Check the perimeter of the door bellow (gray rubber seal) and make sure no small articles of clothing are left in the rubber folds. Clean this area thoroughly and dry. NOTE: Anything left behind will mildew over a period of time causing foul odors.
8. Clean the detergent dispenser drawer of any remaining water or fabric softener residue.
9. Store washer, unplugged in an upright position.
Secondary Method:
If you cannot find RV antifreeze (or prefer not to use it), another method of draining the washer is to remove the drain hose from the standpipe at the wall and pull a vacuum on the line with a wet/dry shop vac. This will pull any remaining water from the drain pump and lines.
If a shop vac is not available, lowering the drain hose from the standpipe to the floor will allow it to drain using simple gravity. IMPORTANT: On a front loader, you may have to remove the drain line from the drain pump to drain the pump. Or, use the access cover (if equipped). Most front loader pumps are accessed by removing the lower panel directly below the door.
Taking the Washer out of Winter Storage:
To remove antifreeze from the washer following storage, run the appliance on a complete cycle with detergent and NO garments added.
I hope you find this information helpful. If you have any questions, please let me know.
Washing Machines Logo
why the pump on troy bilt pressure washere keeps going bad?
you need to use briggs and stratton pump saver over winter to keep water from freezing and keep the pump lubricated. also never start it if the hose is not already turned on and supplying water to it.
Aug 02, 2017 | Troy Garden
CAN I PUT THIS REFRIGERATOR IN THE GARAGE??
yes of course you can they even work when in an unheated garage
Jan 25, 2016 | Refrigerators
how to store for the winter
in a garage out of the weather would be fine
Dec 06, 2009 | Electrical Supplies
Proceedure to winterize washer
HI thanks for your question. the easiest way is to. pour plumbers anti freeze in it 1 gallon should do it . thanks the appliance doc. oh, start it up in the wash cycle for a few minutes, to cycle the water.
Oct 01, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Dec 11, 2007 | Refrigerators
3,023 people viewed this tip
Top Washing Machines Experts
