Tip & How-To about Computers & Internet
To create a shutdown,reboot, logoff icon on your desktop (XP)
Right click on an open area of the desktop>> Select New>>Shortcut Enter in
shutdown -s -t 0 (for shutdown button)
shutdown -r -t 0 (for Restart Button)
shutdown -l -t 0 (for Logoff button)
Note: Only enter the text in bold.....and not the text inside bracket.Press Next For the name, enter Reboot or anything you like.
Click Finish.
Computers & Internet Logo
my laptop acer aspire5920 is not shutting down due to removal of my shutdown file from my laptop due to unknown reasons.
Hi dear,
Create Icons for Shutdown and Reboot If you find it annoying to access the Start Menu for shutting down or rebooting the computer, create a shutdown and reboot icon for the desktop.
Desktop Shutdown Icon Right click on the desktop
Click [New] [Shortcut] to open the Create Shortcut Wizard
Type [shutdown -s -t 00] without the brackets.
Click [Next] and type a descriptive name of your choosing for the shortcut
Click [Finish]
Add a bit of class to the shortcut by assigning it a custom icon. Right click the shortcut, click [Properties] and select the [Shortcut] tab. Click [Change Icon] and select from the icons that are displayed.
Desktop Reboot Icon Right click on the desktop
Type [shutdown -r -t 00] without the brackets.
Click [Finish]
A Final Note: If you happen to be as fanatical as I am about having nothing on the desktop, drag the new icons into the Quick Launch area of the Taskbar.
then use it.
if not resolve it
then use following step ;-
click on start then go to RUN and type SFC /SCANNOW
press enter
this command recover all windows lost files, if it will ask windows CD then enter the windows disk.
bye take care
good luck
veeru
May 07, 2009 | Acer Aspire 5920 Notebook PC
Shut Down Problem & Have to Reset Computer Battery
Hi, I had the same problem, for a workaround this is what I did. I made a new shutdown shortcut. Now when I click on it the pc shutsdown fine. I actually put mine on the taskbar. Here's how I did it...
XP Users:
1. Right click the Desktop and select New /Shortcut.
2. A screen will appear asking you for a Command Line. Here's what you put in that box:
For Shutdown:
Shutdown -s -t 0
For Restart:
Shutdown -r -t 0
For Log Off:
Shutdown -l -t 0
After you've decided which of the above options to use, click the Next button and give the shortcut an appropriate name.
Final Notes:
1. Now that you have the nifty little shutdown shortcut on your desktop, you may want to drag it to your taskbar for easier access (and less chance of accidental clickage).
2. I didn't like the nasty looking icon that XP gave my shortcut (it was too Win3.1 for my taste), so I changed it.
If this helps you plz rate this 'fixya'. If not leave a comment & I'll be happy to try to help you further. Thank you kindly.
Feb 12, 2009 | Dell Dimension™ B110 PC Desktop
dell model DHM DESKTOP which is stuck while plug in .
Try this out:
1. Hold down the Start (Windows Flag Key) button on your keyboard and press R
2. Type this Command : shutdown.exe -s -f -t 00
This will shutdown all running programs and shutdown windows Instantly.
Optionally you can create a desktop shortcut to do this automatically. Here is how:
1. Right click on any blank space of windows desktop -> New -> Shortcut. A “Create Shortcut” window will open.
2. In the blank, type in:
It means, shutdown and wait for Zero second. Click “Next” button for next step.
3. Type in whatever name you like in the blank. I use “Turn Off PC”. Then, click “Finish” button.
4. You are finished . A new shutdown shortcut has been created on your windows desktop!
Just click on it to shutdown.
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
853 people viewed this tip
David Payne
David Payne
